Ron Laden | 16/02/2020 15:49:57 |
![]() 2320 forum posts 452 photos | I think I can squeeze in another project before getting back to the Class 22, I am going to have a go at a Jasons MkII version of the Jowitt Popett Valve Engine. I think Jason said it is approximately 30% larger than the original having a 24mm cylinder bore. Fortunately Jason has one of his excellent build threads complete with drawings here on the forum so that is a real bonus. I really like the look of the engine and its a bit more advanced than the little Muncaster oscillator I have been building so a bit of a step up so to speak. Still waiting for the flywheel to finish the oscillator so having some material to hand I made a start on the Jowitt side frames this morning, going well so far.
JasonB | 16/02/2020 16:08:15 |
![]() 25215 forum posts 3105 photos 1 articles | I thought you had been a bit quiet this weekend Ron, now I can see why. You look to be off to a good start. |
Ron Laden | 16/02/2020 16:25:07 |
![]() 2320 forum posts 452 photos | Thanks Jason, I did spend a fair bit of yesterday reading your build thread (twice) and studying the drawings to make sure I was happy which I am. You probably noticed that I did live a bit dangerously today though, I should have set the frames up a bit further out of the vice. I was half way through cutting the large rad when I thought I was going to crash into the vice. I checked the dimensions and fortunately I cleared the vice at full rad buy a gnats whisker about 0.6mm.. Edited By Ron Laden on 16/02/2020 16:26:36 Edited By Ron Laden on 16/02/2020 16:29:09 |
Ron Laden | 17/02/2020 06:49:42 |
![]() 2320 forum posts 452 photos | Morning Jason, Just out of interest do you know how many of your MK11 Jowitts have been built. Ron |
JasonB | 17/02/2020 07:04:30 |
![]() 25215 forum posts 3105 photos 1 articles | JimNick on here has made one, Chris Gunn did at least three and a couple of others that have posted. |
John Baron | 17/02/2020 08:28:09 |
![]() 520 forum posts 194 photos | I've been collecting the materials to make one ! I just need a piece of cast for the cylinder block.
Jim Nic | 17/02/2020 10:35:21 |
![]() 406 forum posts 235 photos | Hi Ron As Jason says I built a Jowitt from his plans. You may see the resemblance. Being a bit careful with a penny, I made the flywheels rather than buy in a pair of castings. The wee brass pulley came from my come-in-handy drawer. Jim
Edited By Jim Nic on 17/02/2020 10:35:48 |
Ron Laden | 17/02/2020 13:07:58 |
![]() 2320 forum posts 452 photos | Posted by John Baron on 17/02/2020 08:28:09:
John, I am going with aluminium for the cylinder, Jason mentioned in his thread that alu was an option so thats what I am going to try. |
Ron Laden | 17/02/2020 13:18:32 |
![]() 2320 forum posts 452 photos | Posted by Jim Nic on 17/02/2020 10:35:21:
Edited By Jim Nic on 17/02/2020 10:35:48 Very nice Jim, I hope mine turns out as well. I think it a really nice looking engine, the shapely cylinder block and the twin flywheels. Also watching Jasons videos it sounds good to. Ron |
Former Member | 17/02/2020 13:49:52 |
1329 forum posts | [This posting has been removed] |
JasonB | 17/02/2020 14:03:41 |
![]() 25215 forum posts 3105 photos 1 articles | Bill, I give some history of the engine in my thread here I don't think I had this photo at the time I did the build but it shows most of an original casting set with aluminium cylinder casting. Photo by Jo T. Edited By JasonB on 17/02/2020 14:11:18 |
Former Member | 17/02/2020 14:16:59 |
Ron Laden | 17/02/2020 16:34:53 |
![]() 2320 forum posts 452 photos | The side frames are just about there, still need to machine the 3.6 degree angle to the ends and sides. I have sent off for a digital protractor, I have been meaning to get one for a few weeks so now is a good time. I machined most of the side frames with the ARC 25mm two insert end mill. I have been using it a lot lately, very good should you need to remove a fair amount of material and the surface finish is excellent, really impressed with it. |
JasonB | 17/02/2020 16:50:00 |
![]() 25215 forum posts 3105 photos 1 articles | Ron, the angle is not critical but if you can't wait for your new toy 3.6degrees works out quite close to 1/4" in 4" or 3/8" in 6" so easy to arrange some packing at those distances to set things up. |
Ron Laden | 17/02/2020 17:41:14 |
![]() 2320 forum posts 452 photos | Thanks Jason, if I had thought about it a bit more I should have realised that the angle is only cosmetic so close enough will be ok. I will give it a go in the morning. Ron |
Ron Laden | 18/02/2020 08:05:12 |
![]() 2320 forum posts 452 photos | Up early and machined the angled ends and sides, went well and the transition to the vertical at the crank mount turned out ok. |
geoff walker 1 | 19/02/2020 11:13:46 |
521 forum posts 217 photos | Hi Ron G'day mate, looks like another great build log Keep posting Geoff in Kings park Perth WA (Rick astley concert) |
Ron Laden | 20/02/2020 15:40:27 |
![]() 2320 forum posts 452 photos | Would anyone know where I can get a sprung centre for the lathe, I must be looking in all the wrong places as I havnt found one yet, well I tell a lie I found one but I am not paying £56 for one. I also wondered if its ever been featured in tool making over the years, I cant imagine they are too complicated. |
JasonB | 20/02/2020 15:49:07 |
![]() 25215 forum posts 3105 photos 1 articles | I know a very nice man who would be only too willing to sell you one. or even more. Personally I don't use them just a bit of silver steel with a point held in the tailstock chuck and push the tailstock to keep the pressure. Hole in the other end drilled with a CTR drill will allow you to use taps that don't have a hole in the end. Or are you looking at my long one for setting up work in the 4-jaw?
Edited By JasonB on 20/02/2020 15:53:15 |
Journeyman | 20/02/2020 15:49:16 |
![]() 1257 forum posts 264 photos | Found *** These *** on Amazon, no idea if they are any good but there must be others about. John Jason beat me to it by a few seconds: The ones from Arc are about the same price as Amazon so definitely a better bet. Edited By Journeyman on 20/02/2020 15:53:52 |
