terry callaghan | 16/02/2020 13:34:15 |
237 forum posts 10 photos | Hi chaps. I need to add an extension to the reverser, as the tender is 3 foot long and there is know way I will be able to operate this control. I will need to add a few u/j joints to the hex side of the reverser to allow me to operate this control from behind the tender. As anyone some good idea of the best way to do this, thanks. Michael |
Simon Williams 3 | 16/02/2020 13:56:39 |
728 forum posts 90 photos | Piece of flexy drive out of a brush cutter? (The kind with a droop snoot instead of a bottom gearbox)
terry callaghan | 16/02/2020 14:53:35 |
237 forum posts 10 photos | Hi simon, will take a look, thanks. |
duncan webster | 16/02/2020 17:30:36 |
5307 forum posts 83 photos | Geared electric motor? |
Nigel Graham 2 | 19/02/2020 00:38:37 |
3293 forum posts 112 photos | I think you can still buy flexi-drives for electric drills. One of those might be suitable, with appropriate adaptors. |
terry callaghan | 19/02/2020 09:37:30 |
237 forum posts 10 photos | Thanks chaps, some good ideas. I don’t think an electric motor will work Duncan as it’s too near the firebox door. My worry with smaller flex cables is that they bend up if there is too much torque applied. The reverser does take some effort to move. I am going to a garden machine repair shop today to see what’s available. Will get back. |
Clive Foster | 19/02/2020 10:14:17 |
3630 forum posts 128 photos | UJ rather than flexi shaft if there is any significant load / stiffness. By the very nature of things flexi shafts tend to wind up a bit under load which will probably give poor feel and make operation imprecise. The one garden machinery flexi shaft I have had anything to do with seemed quite springy and had significant wind up. We concluded that this was a feature not a fault as it would act as a drive line shock absorber. Good idea for a brush cutter or similar where the blade is almost certain to hit something pretty solid several times during the machines life. Seem to be a decent selection of affordable UJ joints around from various suppliers. Once used a socket set one for a quick'n dirty temporary job. Worked but not particularly wonderful in operation compared to proper UJ joints. Clearly made for strength not smoothness. When you are trying to teach a stubborn nut or bolt manners an extra ft lb or two to drive the joint is pretty inconsequential. But a control needs to be smooth. Clive |
terry callaghan | 20/02/2020 09:09:59 |
237 forum posts 10 photos | Hi, yesterday I looked at a few flexi cables, but they all had torque bend, bar the very large ones. So I had a look in Halfords. I picked up a few 1/4 inch uj joints and think that in the end this will be a better bet. Will update as I go along with the project. Thanks for input. |
Dalboy | 20/02/2020 10:02:19 |
![]() 1009 forum posts 305 photos | Have you thought of a couple of long model boat prop shafts and the UJ joints that you can get to suit they would be OK for most of the joints but not the one near the firebox as they have plastic in them.
terry callaghan | 20/02/2020 10:07:07 |
237 forum posts 10 photos | Hi Derek, yes I know the ones you mean. Will take a look, thanks for that input. Good idea. |
Dalboy | 20/02/2020 10:30:43 |
![]() 1009 forum posts 305 photos | HERE are some long props that I found up to 508mm long. I drilled a hole in some of mine and soldered an upright tube to it and then fixed a small paint tin to the top of that this allowed for lubrication of the tubes. Granted your use of them will not involve the same rotation speed a model boat needs. |
terry callaghan | 20/02/2020 13:38:26 |
237 forum posts 10 photos | Derek, I think you have hit the nail on the head. But one thing remains to be looked at to make this work. As the locomotive turns a bend so the cap between it and the tender gets wider or shorter. This could be around an inch or more on my loco. So to allow for this movement some sort of movement most be allowed in the extension. I have been thinking of a slide made up of two flats around two inches long. One slide would have a slot in it, the other two pins that run along the slot allowing for the reduction of length needed or the increasing length due to the movement of the locomotive as it takes the bend. I have ordered some uj joints that can take 6mm rod. Maybe a bit overkill but I don’t want torque bend. It’s not the rotation speed that worry’s me, it’s the torque that is needed to move the reverser. |
Dalboy | 20/02/2020 14:04:13 |
![]() 1009 forum posts 305 photos | A square tube with a square bar that slides inside and an UJ joint at either end will allow for the narrowing and expanding of the gap but still allow for it to be rotated |
terry callaghan | 20/02/2020 14:19:47 |
237 forum posts 10 photos | I like that idea. Will have a think on that. Thanks |
duncan webster | 20/02/2020 15:12:19 |
5307 forum posts 83 photos | to eliminate the need for telescoping as you go round a bend you could let the long rod slide through a spherical bearing, so it just goes in and out ( no rude jokes! ). I can't imagine it moves much |
terry callaghan | 20/02/2020 16:36:44 |
237 forum posts 10 photos | Hi Duncan, interesting idea, but it’s becoming more complicated. I like to keep things simple, like me. |
