Can anyone recommend a cutting disk for cutting aluminium?
Richard Rogalewski13/01/2020 12:16:28
72 forum posts
14 photos
Hi. I'm just wondering if anyone has looked into buying a cutting disc for aluminium, or tried a few products and is in a position to recommend a particular brand/model?
I'm limited at the moment to a size of 210,/30
I figure that buying a disc by Milwaukee at £66.04 (Ex VAT) is bound to produce good results and last, but it's rsather expensive. I'm thinking about spending £30 tops and less if possible. Thanks. Rich
JasonB13/01/2020 12:23:09
Do you mean a saw blade rather than an abrasive disc as your sizes would suggest a saw blade.
ega13/01/2020 12:37:26
2805 forum posts
219 photos
I think the Project Binky boys on YouTube use an ordinary grinding/cutting disc (I appreciate AA is a different proposition from steel).
Axminster have cutting discs in their sale - cheap enough to try, perhaps.
Edited By ega on 13/01/2020 12:38:58
JasonB13/01/2020 13:03:28
You can get abrasive discs for aluminium but the sizes quoted 210dia and 30 bore suggest a chop saw needing a negative rake blade, price is also in teh blade bracket.
Tooth count would depend to some extent on whether box section or solid bar being cut.
Edited By JasonB on 13/01/2020 13:04:49
Richard Rogalewski13/01/2020 15:08:05
72 forum posts
14 photos
I mean a saw blade. Rich
EDIT: Also thinking about modifying my machine to take saw blades with 25.4mm bore.
Edited By Richard Rogalewski on 13/01/2020 15:10:26
John Reese13/01/2020 21:39:37
1071 forum posts
I have an Evolution Rage3 that is intended for metal cutting. The primary fratures of the blade are negative rake and a depth of cut limiter ahead of each tooth. I wanted to put a fine tooth wood cutting blade on the saw. The blade was a 5/8 bore and the saw has a 1" arbor. I set the wood cutting blade on 1-2-3 blocks and clamped it down. I indicated on the center hole and started boring until I got to 1".
John Reese13/01/2020 21:45:04
1071 forum posts
Triple chip saw blades are great for Ali. Actually almost any wood cutting blade works.
If you areusing an abrasive disc on aluminum select silicon carbide abrasive, commonly used in concrete. The AO discs have strong grains that don't fracture and break away hence the load up and quit cutting Ali. SiC blades have very sharp grains that are brittle and break down in use. That keeps fresh abrasive exposed.
