Martyn Duncumb | 02/01/2020 22:09:37 |
55 forum posts 3 photos | 3/32" was a popular thickness of strip steel in various widths specified in articles in ME in the 60s and 70s. Apart from round 3/32" none seems to be available now and the metric equivalent of 2.5mm does not seem to be listed either. What does one do to get round this? Machine down from the next size up? Thanks Martyn |
Andrew Johnston | 02/01/2020 22:19:35 |
![]() 7061 forum posts 719 photos | Unless some of the model engineering suppliers list it you'll need to cut from 2.5mm cold rolled sheet. Andrew |
Roger Vane | 02/01/2020 22:57:56 |
108 forum posts 18 photos | Maidstone Engineering list 3/32" flats - 3/4" and 1" wide. (Phone no: 01580 890066) |
Martyn Duncumb | 03/01/2020 11:24:35 |
55 forum posts 3 photos | Many thanks for your suggestions. Can see now that sheet or broader strips can also provide what I want. Martyn |
duncan webster | 03/01/2020 20:03:20 |
5307 forum posts 83 photos | If we are talking bright strip, beware of cutting down the middle of say 3/32 * 3/4 to get 2 bits of 3/32*5/16, you will get 2 nicely curved bits. Been there, done that. |
Martyn Duncumb | 03/01/2020 20:24:55 |
55 forum posts 3 photos | Thanks Duncan, point noted. Martyn |
Tomfilery | 04/01/2020 10:08:42 |
144 forum posts 4 photos | Martyn, You can still buy "key steel" in imperial sizes, but it will be expensive. I assume it is used for keys to fix gears to shafts, so may not come in the exact size you need. Regards Tom |
Andrew Johnston | 04/01/2020 10:22:04 |
![]() 7061 forum posts 719 photos | Keysteel is normally a thou or two oversize so it can be filed/machined to fit the keyways. Andrew |
DiogenesII | 04/01/2020 11:05:07 |
859 forum posts 268 photos | GLR Kennions still supply in 3/4 & 1" widths.. |
JasonB | 04/01/2020 13:01:06 |
![]() 25215 forum posts 3105 photos 1 articles | Depending what you are doing with it and how deep your pockets are there is still quite a wide range of widths available in gauge plate |
