Wanted help with machining small ali components
For competitive advantage!
Peter Martin 1330/11/2019 15:46:46
3 forum posts
Hi,
This is my first post on here. Just to explain where I'm coming from, I make and fly model aeroplanes in competitions at home and abroad. I'm pretty competitive, but short of the top! I've had some ideas recently on how to become a winner, but it needs machining of some small bespoke aluminium components, so I thought someone on here might be able to help. It's not my area of expertise and I'm too busy to get seriously into the world of machining, basically I'd like to give someone the instructions, they make up the pieces and we discuss the reward. Hopefully someone can help, thanks in advance!
Pete
Ian P30/11/2019 22:08:24
2747 forum posts
123 photos
Peter
There may be dozens people here that could make your parts, one of them might live round the corner to you!
Some indication of your location and more (even vague) details of 'bespoke aluminium components' will help garner replies.
Ian P
Peter Martin 1330/11/2019 22:31:24
3 forum posts
Hi Ian,
Thanks for the reply. As a first timer, sorry I don't know how this normally works, I was just posting and hoping! So I live in the Brighton area. And what I want isn't a brand new component but rather machining of blanks to shape, I'll explain more.
On my aeroplane, inside the propeller hub is a cam shape which runs around a circular ali piece at a diameter of about 20mm (I can give exact measurements if it helps). The supplier of these hubs sells them with a standard cam which is basically a falling wedge shape running around the circumference. However, the supplier sells blanks where you can cut your own cam shape, which I would like to do. But short of using a file, a micrometer and tedious hours, I have no way of doing this accurately and smoothly. So I'm looking for someone to help with machining the cams to desired profile.
I will probably look to have several shapes made up, so I can try different ones and see the effect on the aeroplane. How's that? laugh
Cheers,
Pete
Philip Powell01/12/2019 08:04:16
68 forum posts
15 photos
Peter
As a model flyer myself I would like to help. But, cam shapes? It sounds like you need help from somebody with a CNC machine, something that not many amateurs have access to. Have you contacted any of your local machine shops? Sorry I can't be much help but I think what you are looking for is very specialist matching work, cams are not an everyday thing.
Phil
Richard -01/12/2019 08:13:33
62 forum posts
7 photos
Hi Peter,
Can we have a photo, or a link ?
Are we talking variable pitch?
Richard
Edited By Richard - on 01/12/2019 08:18:37
Peter Martin 1301/12/2019 11:52:15
3 forum posts
Hi Philip,
I have been contacted privately by a modeller with not one but two CNC machines, so I might be in business!!
Peter
Posted by Philip Powell on 01/12/2019 08:04:16:
Peter
Phil
