john brown 17 | 01/11/2019 18:40:54 |
135 forum posts 3 photos | Has anyone on here ever made there hand water pump for filling the boiler,and yes l know before l am told you can buy a casting kit ,but has any body made one from bar stock or plumbing bits ,there is a couple on the net who have done it ,but there is no plans ,any help please ,would be nice to make my own . john |
An Other | 01/11/2019 19:11:12 |
327 forum posts 1 photos | There have been several in ME over the years - one designed by LBSC springs to mind - if I remember correctly it is in the construction articles for Tich, and was completely fabricated - no castings. Not at home at the moment - I will try and find it over the weekend if its any help. |
john brown 17 | 01/11/2019 19:25:30 |
135 forum posts 3 photos | An Other have sent Pm |
JasonB | 01/11/2019 19:43:55 |
![]() 25215 forum posts 3105 photos 1 articles | The ME Vertical Boiler series that has recently finished started off with a hand pump from issue 4580 onwards |
David Wasson | 01/11/2019 20:33:56 |
![]() 149 forum posts 43 photos | The hand pump for a Super Simplex by Martin Evans is pretty nice. Here's the one I made for my loco. It would work fine for a stationary boiler as well. This was all made from bar stock. It moves a lot of water and is easy to pump even against 100 psi. The handle on this one is removable, it's a stainless steel tube about 8 inches long. |
john brown 17 | 02/11/2019 18:25:40 |
135 forum posts 3 photos | That is a nice looking pump you have there well done,l remember a few years ago now at a tractor show there was a chap there who had a model steamer that he was filling the water with a converted car fuel pump ,he just had a small handle fixed to the arm that used to run off the car cam ,wish now l had paid more time to looking at it ,mind it seemed to work very well and a cheap way to make a pump,so just a thought. |
David Wasson | 02/11/2019 20:05:09 |
![]() 149 forum posts 43 photos | Thanks John, If you are interested in drawings for this pump I can probably help you out. Send me a PM if you are interested. I changed which end the pump discharges from. I also made the intake holes in the bottom closer to the pump body. I also added a packing nut to the pump ram. I usually use drawings like these as a point of departure and modify things as needed. Here's a link to a few photos of the construction of this pump: https://supersimplex.yolasite.com/Emergency-Hand-Pump.php David Edited By David Wasson on 02/11/2019 20:09:01 Edited By David Wasson on 02/11/2019 20:11:40 |
