Fuel
john brown 1717/10/2019 19:50:42
135 forum posts
I am working along on one of my models and have built the fuel tank and burners that will use meths or the like,but the more l think about it would l be better off and more safe if l went over to a gas set up and use butane ,l se you can get cheap pen type soldering irons that l could cut up an use the bits from that and make a tank ,any thinkings on this please.
john
mick H17/10/2019 21:04:23
795 forum posts
34 photos
I use both meths and butane in my models (although not both at the same timewink). Butane is clean and easy if you get the burner /jet set up correctly but meths is a lot more fun. As far as performance is concerned, there is very little difference between the two fuels in my experience ......again depending on boiler / burner setup.
Before you waste money on gas soldering irons, you can get "Ronson type" gas fillers cheaply on EBAY. You will also need a suitable tap for them though. I don't have the information immediately to hand but I seem to recall that it is M4.5.
Mick
Bazyle18/10/2019 13:35:51
6956 forum posts
229 photos
Have a look around G1 and 16mm forums and websites for burner designs and gas tanks.
Former Member18/10/2019 14:00:49
1329 forum posts
