RICHARD CALLIS | 26/09/2019 14:04:53 |
3 forum posts | Hi to all I'm building the boiler and under the 2018 reg. the water gauge and injector cannot come off the same manifold, as anyone split the two. Cheers |
Neil Wyatt | 14/10/2019 11:19:37 |
![]() 19226 forum posts 749 photos 86 articles | Hi Richard, I've moved this post to the Traction Engine topic, so you may get some replies! Neil |
Former Member | 14/10/2019 12:03:32 |
1329 forum posts | [This posting has been removed] |
JasonB | 14/10/2019 13:41:37 |
![]() 25215 forum posts 3105 photos 1 articles | Bill see my answer in the other thread, Only one bush for the lower water gauge fitting on the drawings. Edited By JasonB on 14/10/2019 13:42:42 |
Former Member | 14/10/2019 13:45:29 |
Former Member | 14/10/2019 13:48:33 |
JasonB | 14/10/2019 14:01:34 |
![]() 25215 forum posts 3105 photos 1 articles | You are wrong Bill. As I said there is only one water gauge bush on the backhead and 3 blind nipples for door hinge and lock. The top water gauge, pressure gauge, injector feed and water lifter feed all come off the manifold which has a single passage from boiler. |
Former Member | 14/10/2019 14:13:35 |
JasonB | 14/10/2019 14:19:53 |
![]() 25215 forum posts 3105 photos 1 articles | Bill as I said in the other thread the first 3 allchins that I looked at are all as per the drawing, you are not looking at bushes where the top WG , injector etc fit into but the rear of the manifold which just pokes through teh specticle plate Edited By JasonB on 14/10/2019 14:20:35 |
Former Member | 14/10/2019 14:23:07 |
Former Member | 14/10/2019 14:28:59 |
JasonB | 14/10/2019 14:36:14 |
![]() 25215 forum posts 3105 photos 1 articles | Bill, I have marked the top curve of the backhead in green. What you see as "boiler bushes" are above the top of teh boiler due to them being the manifold |
Former Member | 14/10/2019 14:43:29 |
