oliver p. | 04/08/2019 19:30:57 |
5 forum posts | Hi Guys, I am new to the forum and this is my first question here So I have already built several Stirling motor models, and I thought it would be time to make something "bigger". I have no particular application for it, just for fun. What I would like to do is a steam engine model having 3 or 4 cylinders. While I was searching on the web for some inspiration, I found this plan by accident:
http://www.john-tom.com/MyPlans/Steam%20Engines/RotaryValveEngine.pdf
It looks very nice, but has two cylinders only. But I like the "Rotary Valve" it has, so I wonder whether it would be possible to extend this design to 3 or even 4 cylinders. I already started to make some simple 3D drawings to figure out how I should design the rotary valve, but so far I was not yet able to figure it out. So can anybody give some hints about this? is it possible? For 2 cylinders, the notches in the rotary valve need to be 90 degrees apart from each other; so I assumed for 3 cylinders, 60 degrees would be appropriate, but this is not true (or I made a mistake
mick H | 04/08/2019 20:49:47 |
795 forum posts 34 photos | Hallo Oliver and welcome. I have made the two cylinder version and a nice little motor it is, running smoothly and economically from a 2.75 diameter vertical boiler. It suffers from not being a "self starter" if the crank ends up in the "wrong" place when stopped. I have found a way around that though. If you can figure out the valve events for a 3 cylinder version it would be of great interest. Mick |
John Baron | 04/08/2019 21:27:13 |
![]() 520 forum posts 194 photos | Hi Guys, I've seen an 18 cylinder rotary valve engine ! It was used in aircraft some years ago. Very reliable I understand and well liked by pilots that flew aircraft with that engine. I might have a picture of it somewhere.
duncan webster | 04/08/2019 22:09:39 |
5307 forum posts 83 photos | To be pedantic, that's a semi rotary valve. To have 4 cylinders at 90 degrees you'd need 2 valves. The fit on the rotary valve needs to be pretty good. Edgar Westbury did several steam engines with rotary valves, one being a radial, but I don't have any leads to drawings I fear |
oliver p. | 05/08/2019 08:49:15 |
5 forum posts | @ Mick cool! have you used the very plans I posted in the link? and how did you overcome the starting problems? I think if there are 3 or more cylinders, the engine will self-start no matter in which position it was stopped previously.
@ duncan you are right. The valve does not really rotate in this case but oscillates. I think the construction could be a bit simpler if there is a separate valve for inlet and exhaust. If I could post a screenshot of my 3D CAD model, we could probably figure out how the valve needs to be done, but so far I didn't find out how to attach a picture to a posting here So do you think it should be possible to have this design with 3 or more cylinders?
mick H | 05/08/2019 09:29:53 |
795 forum posts 34 photos | Yes, Oliver it is the same engine but I did make a few alterations / additions. Firstly I ran the crankshaft and crankshaft valve linkage in miniature bearings (arguments for and against). Secondly, I fitted Viton piston rings. There is a feed pump mounted on the RH side of the engine driven by an eccentric on the valve and a Roscoe lubricator fitted opposite the steam intake. I may also have tinkered with piston diameters but I can't remember the details. Duncan is quite correct regarding the valve being a good fit. I lapped it in and have surprisingly minimal leakage, mainly at the feed pump end. I am working on an O ring based solution to this. As regards the self starting problem, I have fitted a needle roller clutch (one way) bearing to the output end of the crankshaft which just requires a nudge from a servo to push the piston past TDC and away she goes. The engine is shamefully filthy at the moment but if you would like a picture I will clean it up. Mick
oliver p. | 05/08/2019 09:52:14 |
5 forum posts | Posted by mick H on 05/08/2019 09:29:53:
sounds very interesting! if you have some nice pictures that would be really interesting
