AJW | 30/06/2019 17:41:02 |
![]() 388 forum posts 137 photos | I need to drill some 1mm holes in a stainless steel watch bracelet clasp, exact grade unknown but of Russian origin. Didn't get very far with the first hole and wondered if it can be annealed? and thought I'd ask before turning it all black! (although it could be cleaned up)
Alan |
Thor 🇳🇴 | 30/06/2019 18:58:42 |
![]() 1766 forum posts 46 photos | Hi Alan, If it is austenitic stainless steel you should be able to anneal it by heating but you need a high temperature and then quench. When drilling stainless steel socalled Cobalt drills may be useful and don't let the drill rub. It need to be cutting all the time. Thor |
Bazyle | 30/06/2019 19:16:27 |
![]() 6956 forum posts 229 photos | Try it with a file. It is unlikely to be the expensive high CR austenitic when cutlery grade would do and in most applications be better. |
old mart | 30/06/2019 19:35:04 |
4655 forum posts 304 photos | Keep the speed of the drill dead slow and only use sharp ones. Maybe you could get some carbide drills. I believe austenitic ss is non magnetic. |
duncan webster | 30/06/2019 20:49:42 |
5307 forum posts 83 photos | Sounds like a job for a spark eroder. Not too difficult to make, see **LINK** |
AJW | 30/06/2019 21:22:44 |
![]() 388 forum posts 137 photos | Thanks for your replies. I have attempted to drill (slowly) and it would appear to work harden very quickly. The existing holes present would appear to have been punched, shall have another attempt with a shorter drill this time as I broke the first!. If it isn't austenitic s/s and I heated it to those high temperatures followed by a quench could that turn it harder/more brittle?
Alan |
Thor 🇳🇴 | 01/07/2019 06:21:42 |
![]() 1766 forum posts 46 photos | Posted by AJW on 30/06/2019 21:22:44:
If it isn't austenitic s/s and I heated it to those high temperatures followed by a quench could that turn it harder/more brittle? Alan If the stainless steel is martensitic that would harden the steel. If it is martensitic cool slowly. I would try with a HSS cobalt drill, a short one is less likely to break. Try a higher speed and more aggressive feed and use coolant. Thor Edited By Thor on 01/07/2019 06:22:23 |
Hopper | 01/07/2019 07:57:57 |
![]() 7881 forum posts 397 photos | Carbide burr in a Dremel tool. |
