Book that explains materials, electrodes and techniques for tig welding copper components
robert eggleston | 14/06/2019 18:06:20 |
28 forum posts 9 photos | Looking for any book describing tig copper welding, electrodes, settings, techniques and other info to help an experienced aluminum welder transition to copper materials. |
Boiler Bri | 14/06/2019 19:00:50 |
![]() 856 forum posts 212 photos | Hi. You are looking for something that is treat as a dark art. We have tried at work using standard kit. tig with standard tungstens and argon back purging. The result was ok. I have heard that using another type of gas that i can not think of the name keeps the heat better on the job. There is an American guy the demonstrates it on you tube i will have a look around and post when i find it. Bri |
DC31k | 14/06/2019 20:29:41 |
1186 forum posts 11 photos | Have you looked at the Copper Development Association website? There is all sorts of technical information there. They have a publication search (although the reference I found to 'Modern methods of welding copper' was dated 1943. Modern, I suppose, compared to Modern machine shop practise by Joshua Rose, from 18-something). I believe the alternative (and original) gas is helium. This gives a hotter weld pool. Hence the original name for TIG, heliarc. Argon is used now as it is way cheaper. |
