Mystery lathe backplate
old mart09/06/2019 18:24:29
4655 forum posts
304 photos
I have just bought a new 4" Burnerd chuck with both sets of jaws, model N30. Definitely imperial as the fixing screws are 1/4" Whitworth.
It came with a backplate which I have failed to identify, even by googling.
The backplate is held on the spindle by three 5/16" BSF studs at approximately 49mm pcd. From slight witness marks the flange of the spindle is 62mm diameter. A tapered projection of the spindle around 36mm with an included angle of about 11 degrees centralises the backplate.
Someone must know.
David George 109/06/2019 20:17:11
2110 forum posts
565 photos
A picture would help to identify please.
David
Howard Lewis10/06/2019 10:44:14
7227 forum posts
21 photos
If the chuck is new, it seems odd that the fixings are 1/4 BSW, rather than Metric. But given that, you would expect the the other dimensions to be Imperial also, rather than Metric
The closest Imperial size to "approximately 49mm" would be 1 29/64" (1..9219" ),
or more likely 1 15/16 (1.9375" - 49.2125 mm )
old mart10/06/2019 12:38:09
4655 forum posts
304 photos
_igp2346.jpgI will try and post a couple of pictures. The chuck is unused but pretty old, made in England, definitely predating the metric 100mm versions. Having stripped, cleaned, lubricated and re assembled it is a beauty, both sets of jaws are tight and body and jaws serial numbers match. I couldn't resist the price, £45.50 including postage.
Edited By old mart on 10/06/2019 12:47:00
old mart11/06/2019 16:59:06
4655 forum posts
304 photos
The mount on the Siege SC6 looks a bit like a contender.
http://www.mini-lathe.com/C6_lathe/C6/c6.htm#Chuck and Chuck Mounting
Howard Lewis11/06/2019 21:23:47
7227 forum posts
21 photos
If it old, but unused, I would expect the dimensions all to be Imperial.
However, that would not stop someone from making a backplate with a Metric OD, and fixings.
But the register would still need to be Imperial, as will be the PCD for the Backplate/Chuck fixings.
Howard.
