Harrison L6 weight ?
Pete White01/05/2019 18:49:36
223 forum posts
16 photos
I have a friend needing to move an L6 who asked if I knew the weight ? Having searched on line I have come up with 970kg which I think is not correct. I have an L6 with manual and the weight is not in there !!
My A & S 1ES weights in around the 900 kg mark but I can't see the L6 being up there, might be wrong, often am, ask She. lol
Nick Thorpe01/05/2019 19:03:58
53 forum posts
6 photos
Like you I found a manual with no weight which is strange.
This Harrison comes in at 1,230 pounds if that helps?
See Ebay US
Nick
Pete White01/05/2019 19:09:46
223 forum posts
16 photos
Thanks for that Nick, that's about where I had it. smiley Thought I might be losing it ! probably am. lol
Paul Kemp01/05/2019 20:40:48
798 forum posts
27 photos
Pete,
I have an L6 which came with all original documentation and like you in the manual I found no weight. However, I also have the seperate specification leaflet which gives the approximate weight of the 24" as 1540 lb or 698kg and for the 40" (how I would love one of those) 1708 lb or 775kg. The 24" copy version is 1736 lb or 787kg and the 40" 1932lb or 876kg. I think those weights are pretty accurate for the machines as they also give the size and additional weight of the packing cases!
Mine is the 24" and we had to extract that from a shed down a garden on a hill and then roll it out to the road on pipe roles before picking it up with an engine crane (which was on its limit) and roll a 750kg plant under it. It certainly sat the trailer down on its haunches so again I would say the above weight is pretty close to the truth.
Hope that helps.
Paul.
Pete White02/05/2019 10:02:22
223 forum posts
16 photos
Thank you Paul,
Great information. We are talking the 24 inch version here, so not to bad. We can also see where that 970 kg "for the big one" came from.
The power of the forum !
Pete
