Direction of Blank Roll and Offset cutting gears for Shay Locomotive
Robert Blodinger | 23/04/2019 06:34:29 |
7 forum posts | I am cutting Bevel Gears per Ivan Law Book for Parallel Depth gears. I just finished the first pass of three. Need to apply the Blank Roll now of 2.25 degrees. Using my rotary table set up on the Mill, I now have table set to 360 degrees, and just finished milling the first pass, having cut the slot between tooth 40 and tooth one. The required blank roll is 2.25 degrees. When I rotate the gear clockwise by 2.25 degrees, I will be bringing the cutter to cut more of the right side of tooth 1. So to now apply the offset which is .023 inch or .58 mm do I raise the cutter which will cut more of the right side of tooth 1, or lower the cutter. In other words I am moving both cutter and roll to cut more of the right side of tooth 1 and less of the left side of tooth 40. I have cut bevels before but been a while and cannot remember and Law sure does not give an answer other than pictures which has arrows going both way The gears looks good and odnt want to ruin it with a worn turn.
Bob |
JasonB | 23/04/2019 07:03:51 |
![]() 25215 forum posts 3105 photos 1 articles | Page 110 shows which way to move but basically you want the middle of the cutter to still line up with the ctr of the cut at its inner end so if your roll rotation makes the groove lower then lower the tool, if when you roll the gear the groove is above ctr then raise the tool.
Edited By JasonB on 23/04/2019 07:07:28 |
Robert Blodinger | 23/04/2019 07:32:21 |
7 forum posts | Thanks for the fast response and understand. Another question. I have a dividing wheel on my rotarytabale of 28 holes. The table has a 1:72 turn ration, so each rotation moves the gear 5 degrees. I need a roll of 2.25 degrees. 5/28 = 1.78571429 x 12=2.143 degrees or am I better to go 13x2.143 = 2.32 degrees, closer but larger. Other than that to be exact requires that I pull off the dividing plate and put the vernier back on, but that is very troublesome because I have a lot of gears to make.
JasonB | 23/04/2019 07:50:50 |
![]() 25215 forum posts 3105 photos 1 articles | I don't think it will make a lot of difference, not sure what size your gear is but if say 2" dia then it is only a thou off the tooth at its outer edge. If you recalculate the offset to this new angle then that should be reduced. I suppose you could work out the roll for the other gear and go the opposite way so you either have big gaps with big meshing teeth or small gaps in this wheel with larger teeth on the pinion. Edited By JasonB on 23/04/2019 08:40:31 |
Robert Blodinger | 23/04/2019 08:56:35 |
7 forum posts | The gear is 1.627 in on the large end. The Pinion is .814in on the large end. I guess I will try it at the smaller number on the Gear and then make the pinion and modify it if it does not roll without binding. Actually, come to think of it, the gear is 40 tooth and the pinion is 20 tooth. The blank roll is 4.5 degrees on the pinion and I expect that I can divide that directly since it is half of the 40 tooth 9 degrees spacing but I will have to sit down and calculate whether it will work out to either the 28 hole or 15 hole circle of the division plate. Thanks again, good forum here. Bob
John P | 23/04/2019 10:33:35 |
451 forum posts 268 photos | On page 111 of the gear cutting book about three quarters down the first I see from your later posting that you have a 15 hole plate , The sizes of the gears at the large end do not influence
Andrew Johnston | 23/04/2019 10:39:28 |
![]() 7061 forum posts 719 photos | Posted by John Pace on 23/04/2019 10:33:35:.
The sizes of the gears at the large end do not influence these calculations Correct, unlike normal bevel gears the parallel depth method uses the small end of the gear to set the design parameters. Andrew |
Robert Blodinger | 23/04/2019 18:45:44 |
7 forum posts | John, thanks for the good math. Yes, I saw page 111 and gave up trying to figure out the correct size for a plate. I will go back now and make a 60 division plate. Bob |
