Due to my zealous output, I have been 'advised' to split the original thread.
Sam Stones | 23/04/2019 00:57:03 |
![]() 922 forum posts 332 photos | As a convenience, here is roughly where Thread Part A ended
Unlike the previous exercise where contact of wheel teeth and pinion leaf flanks produced slight changes of contact traces (especially the ‘On centreline and 0.1mm offset), the round pins of the lantern produced smooth curves. Similarly, as here … … the cross-overs of the pressure angles are less severe. Finally, and despite my own luck, only slight changes in depth from the theoretical (i.e. less than 1.0mm) suggest that depthing, at these sizes in particular, needs to proceed with extra care. No doubt for those with depthing experience, you will recognise how the meshing behaves. Too deep and there will be a gnashing of teeth? Too shallow, more gnashing? Links to both albums are here … Meshing with Cycloids https://www.model-engineer.co.uk/albums/member_album.asp?a=50467
Meshing with Lantern pinions https://www.model-engineer.co.uk/albums/member_album.asp?a=50528 Thanks for everyone who helped. Sam Apologies if this mesh came unstuck. |
Michael Gilligan | 23/04/2019 07:03:10 |
![]() 23121 forum posts 1360 photos | Blessed are the Lantern Pinions ... for they follow the true path
Sam Stones | 23/04/2019 20:05:45 |
![]() 922 forum posts 332 photos | Where would I be without your help Michael? Sam I've removed my dark glasses, and can hear much better. |
