David Siddle 1 | 20/03/2019 14:02:25 |
12 forum posts | I'm needing a little help picking the correct drive. I've looked at the manual on line, but I'm still a bit confused Could anyone please tell me if the following model would be suitable for powering my 3ph fobco from domestic supply? Many thanks. FR-D720S-042SC-EC
David
Wingo | 20/03/2019 14:29:08 |
17 forum posts 1 photos | Hi, This is a 230v input single phase and 220v three phase ouput inverter. Rated at 0.75kw. Your motor will need to support 220 / or 230v phree phase supply, often by connecting in Delta on a dual rated motor. It will 'putting in a box' to protect it with room to be able to loose the heat generated. Then with correct configuration it will then work! If you not sure about the motor put up a photo of the motor rating plate.
Michael |
Brian Hutchings | 20/03/2019 15:10:56 |
19 forum posts | Hello David, You could try giving Direct Drives a call, I found them to be very helpful recently. Brian |
