Round top inner firebox
Ian Butler 105/03/2019 14:56:59
3 forum posts
Flattop or round top fireboxes, what are the advantage of each type?
Ian Butler 105/03/2019 14:58:09
3 forum posts
I look forward to some replys
Phil H105/03/2019 17:08:12
467 forum posts
60 photos
Ian,
I am no expert but here are a few that I know of;
A flat top inner firebox will allow more tubes to be fitted. Apparently, the first third of the tubes length from the firebox is the most effective for transferring the heat, so the more tubes, the better the heat exchange.
The larger outer surface area of the square inner firebox will again allow more heat transfer to take place.
The disadvantage is that the flatter, squarer inner and outer firebox surfaces will need more support in the from of stays. So it could be seen as being slightly more difficult to build. Conversely, the curved surfaces of the round firebox are slightly easier to form and build.
Also, the outer firebox of the simple round topped boiler can obviously be formed using a straightforward length of tube - just cut and open out the sides.
The front firebox to barrel plate on a flat topped boiler is more difficult to form and build.
I am sure more experts will come and add or maybe even dispute what I have written but I think I have captured at least some of the pros and conns.
Phil H
roy entwistle05/03/2019 19:46:39
1716 forum posts
Ian you have a PM see Inbox on green line at top of this page
Roy
fizzy05/03/2019 21:01:56
1860 forum posts
121 photos
Im mid build on a couple of 5" gauge Sweetpea boilers which have totally round fire boxes. No stays of any kind for the firebox tube is a massive bonus - both end plates are stayed. If the top of a conventional type loco boiler is half round no stays are needed in it (joing sides and ends stayed as usual) but as stated previously you lose a lot of tube space compared to a square section plate.
Ian Butler 107/03/2019 11:12:17
3 forum posts
To Phil H, Many thank for your thoughts on inner fire boxes, it answers many of my thoughts.
Ian
