Nick Clarke 3 | 13/02/2019 19:05:54 |
![]() 1607 forum posts 69 photos | Starting to look at inverters and wondered if there were any benefits (or indeed drawbacks) to using a higher rated inverter than strictly necessary - ie would a .75kW invertor be suitable for a .75kW (1Hp) motor or would a 1kW (or larger) be a better choice? Thanks Nick Edited By Nick Clarke 3 on 13/02/2019 19:08:45 |
Thor 🇳🇴 | 13/02/2019 19:28:14 |
![]() 1766 forum posts 46 photos | Hi Nick, Have you read this thread? Thor |
Mike Poole | 13/02/2019 19:30:18 |
![]() 3676 forum posts 82 photos | A 750W inverter should run a 750W motor or less with no problems. Often the actual motor current is one of the parameter settings so a smaller motor can be run at full performance and protected. Some more sophisticated inverters can run a self test to learn the motor that is connected and set relevant parameters. In general there is no point in overrating the inverter. Mike |
Martin Cargill | 13/02/2019 20:35:23 |
203 forum posts | If the price difference between the two is small it may be worth going for the bigger inverter. You never know when you might want to upgrade the motor or the machine.
Martin |
Nick Clarke 3 | 13/02/2019 21:06:45 |
I have now. Thanks Nick |
