New to metal lathes
Seeking advice
Bill Pilkington13/02/2019 12:12:07
10 forum posts
Hi,my name is Bill.Never owned or used a metal lathe. Have turned on a wood lathe. I make snooker cues( 1 piece) but want to make jointed cues, which require brass joints. Hence the need for a metal lathe. Will post questions in the relevant topics.
Vic13/02/2019 13:25:06
3453 forum posts
23 photos
Hi Bill welcome, ask away. I was surprised to see that one of the top cue makers (they were making a cue for Ronnie O’Sullivan) didn’t use a lathe in a video I saw. They did all the shaping on a bench with a plane. The video didn’t show the making of the metal parts though. Mass produced cues do seem to be lathe made however, I guess it’s quicker.
Bill Pilkington13/02/2019 13:53:28
10 forum posts
Hi Vic, the cue John Parris was making for Ronnie O'Sullivan is a 1 piece cue, which are indeed planed by hand. But jointed cues are a different thing.400mm butt (ebony) easily turned on wood lathe. But it's drilling into end grain for jointed cues, and into butt end of both types of cues for small extensions to screw into that a metal lathe is needed.Also for fitting the ferrules. Hope that makes sense.
Vic13/02/2019 13:57:43
3453 forum posts
23 photos
I found the video. They do use a lathe but the boss seemed to say it was only for jointing?
Howard Lewis14/02/2019 01:06:48
7227 forum posts
21 photos
Welcome Bill.
If you are looking for some one to one tuition / demonstration, if you give your location, (Town / Country) you may well get offers of some help, face to face.
You will certainly get advice on here, but seeing directly will be make things clearer, and help you decide on what size or make of machine you need, and how to set it up, and grind tools etc.
It seems likely that you will need to learn how to screwcut, rather than use Taps and Dies. If this is the case, you will definitely need personal help, or it will take a long time, and waste time and material, doing at a distance.
Bill Pilkington14/02/2019 08:01:52
10 forum posts
Howard thanks for your advice, you are right with everything you say.I live in Bolton north west England
Howard Lewis15/02/2019 17:54:27
7227 forum posts
21 photos
Hi Bill,
Is there a Model Engineering Club anywhere near you? If there is, do join, and seek help and help.
Wigan, Rochdale, or Urmston all seem to be within 15 miles..
Take a look on Google
Most Clubs are friendly and folk will be happy to advise and help you on how to set up your machine and explain the strange new patois of the M E world.
Jeff Dayman15/02/2019 18:04:49
2356 forum posts
47 photos
Bill P- there are several responses to your "holding in headstock" thread. Just letting you know. Might be wise to ask the moderators to combine the three threads you started into one, since they all concern the same issue of machining cues to fit brass threaded joints.
Bill Pilkington15/02/2019 21:21:52
10 forum posts
Thx Jeff, will do.
Pete White18/02/2019 09:46:00
223 forum posts
16 photos
How about using a fixed steady on a much smaller lathe than you would need to pass a cue through the spindle ?
Pete
