Practical advice and experience of using Flexible filament
The Novice Engineer | 31/01/2019 23:08:17 |
85 forum posts 72 photos | I'm looking at making some Lens covers [ for Camera and Telescope Lenses ] has anyone got any advice and experience of using Flexible filament. Here is an example of the type of cap Any recommendations on manufacturers of good [ and duff] filaments would also be welcome My 3D printer is a Leapfrog Creatr. Thanks Steve |
Andy Carruthers | 31/01/2019 23:24:19 |
![]() 317 forum posts 23 photos | I am having problems with FFF world FlexiSMART, very soft filament which requires modification to the extruder (on my ToDo list) to reduce the pinch wheel gear diameter to provide better grip Try TPU and see how you get on |
Gary Wooding | 01/02/2019 08:01:37 |
1074 forum posts 290 photos | I've successfully used NinjaFlex in our Ultimaker. |
Neil Wyatt | 01/02/2019 14:33:47 |
![]() 19226 forum posts 749 photos 86 articles | I've used 'no-name' flexible PLA with success. Using a Mk. 8 extruder the 'secret' is to fit a filler block with a hole in it to bridge the gap between the pinch roller and the top of the heatbrake tube. A benefit of such a block is that it allows you to change filaments by pushing the old filament out with the new instead of having to clear the nozzle. Neil |
The Novice Engineer | 05/02/2019 22:41:51 |
85 forum posts 72 photos | UPDATE I found the information here from Madhackers very useful https://www.matterhackers.com/news/how-to-succeed-when-printing-with-flexible-filament or use this **LINK** I bought some Priline TPU filament from Amazon and spent a few hours finding the best setting printing a variety of 20mm cubes. The the standard Leapfrog Creatr feed mechanism seems to be able to feed the flexible filament OK so far. I created a profile for the Filament that had a higher temp than PLA [240 C] and increased the Extrusion multiplier to 1.15. The setting for the Print profile was created using a much lower speed setting , Max speed 30mm/sec down to 10 mm/sec. There is probably scope for tweeking as I print different projects. Steve |
