andrew lyner | 19/01/2019 14:53:23 |
274 forum posts 5 photos | I needed a fine but unspecific thread pitch and it appears to be impossible to achieve some combinations of gears because the swinging plate will not allow it. It is annoying me, just after having sussed out the system; the sums are surprisingly straightforward but real life gets in the way. This must have been a problem for many mini lathe users. Of course there are combinations that are impossible because the larger idler gear can prevent the smaller gear meshing but the swinging idler plate can only swing so far and the straight slot is too short. etc. etc. That prevents otherwise legal combinations.
What's the experience of other mini lathe owners? |
JasonB | 19/01/2019 15:02:46 |
![]() 25215 forum posts 3105 photos 1 articles | Andrew, what do you call fine? Straight out the box it will do down to 0.4mm pitch which is 63.5tpi which most of us here would class as quite fine. |
HOWARDT | 19/01/2019 15:05:32 |
1081 forum posts 39 photos | Have a look here. I made this a while ago, makes life easier.
Michael Cox 1 | 19/01/2019 15:14:13 |
555 forum posts 27 photos | Here is another option: http://mikesworkshop.weebly.com/new-threading-banjo.html |
andrew lyner | 19/01/2019 23:49:31 |
The thread was for the inside of a telescope extension tube. They put fine grooves in the tubes to disperse any light that hits the sides of the tube. So any pitch and depth would be ok, afaik. Both those alternatives seem attractive but they are only one point fixing. How is rotational strength? I suppose the answer is 'sufficient'
SillyOldDuffer | 20/01/2019 10:18:57 |
10668 forum posts 2415 photos | Posted by andrew lyner on 19/01/2019 14:53:23:
I needed a fine but unspecific thread pitch and it appears to be impossible to achieve some combinations of gears because the swinging plate will not allow it. ... What's the experience of other mini lathe owners? Just in case you haven't spotted it, but the mini-lathe banjo has two clamp nuts that can be adjusted to accommodate the gears. My mini-lathes double action banjo was one of the features I didn't care for much - it's fiddly to set-up compared with other types, and the second clamp nut is hard to get at from the front. I guess the double clamp arrangement is used on a mini-lathe because it fits neatly into the limited space available, not because it makes life easy! Aside from that, I don't recall having any difficulty setting up my mini-lathe to cut fine threads, but it is true that the banjo can't take all the combinations of gears that are theoretically possible. This is true of all banjos, not a particular limitation of the mini-lathe. Dave
Dave |
Brian Wood | 20/01/2019 10:27:20 |
2742 forum posts 39 photos | Hello Andrew, Here are two gear set ups for 0.2 mm pitch threads [127 tpi] which would surely be fine enough with the standard issue gears. Change wheels A = 30; B = 60; C = 20; D = 80 ---- Pitch equals 0.198 mm with 16 tpi leadscrew OR A = 20; B = 50; C = 20; D = 60 ---- Pitch equals 0.200 mm with 1.5 mm leadscrew Regards Brian |
andrew lyner | 20/01/2019 10:39:51 |
274 forum posts 5 photos | Posted by Brian Wood on 20/01/2019 10:27:20:
Hello Andrew, Here are two gear set ups for 0.2 mm pitch threads [127 tpi] which would surely be fine enough with the standard issue gears. Change wheels A = 30; B = 60; C = 20; D = 80 ---- Pitch equals 0.198 mm with 16 tpi leadscrew OR A = 20; B = 50; C = 20; D = 60 ---- Pitch equals 0.200 mm with 1.5 mm leadscrew Regards Brian Yeah - I can do the maths but the banjo (far from being a banjo shape) actually gets in the way of many combinations of wheels. The suggested alternatives wouldn't suffer from this, I think. Edit: So I may even need more than one banjo if I want to do all possible mathematical combinations. Edited By andrew lyner on 20/01/2019 10:42:55 |
Brian Wood | 20/01/2019 10:51:11 |
2742 forum posts 39 photos | Hello Andrew, I don't actually own one of these lathes so I am not aware of all the niceties of the limitations arising from the shape of the change wheel banjo, so I have not actually tested those combinations and offered them as calculated arrangements which you may not have tried. You may now have found other ways round that Regards Brian
Howard Lewis | 20/01/2019 17:49:12 |
7227 forum posts 21 photos | Assuming that we are talking about a C3 mini lathe. If the pitch does not matter, for purely a light baffle, to minimise reflections, just set up as fine as possible. Presumably, 20:80/20:80 which will give 0.09375mm pitch with a 1.5mm Leadscrew. If you make two 100T gears, (1 Mod ) and modify the bottom Banjo clamping arrangements slightly, you can get a pitch of 0.06 mm. But the gear cover needs to be modified (hacked about to make clearance for the primary 100T, or removed temporarily ) Howard |
andrew lyner | 20/01/2019 17:50:50 |
274 forum posts 5 photos | Hi Brian One of those links has a picture of the standard banjo. You can see it takes up a lot of room and it bumps into other bits. There is a protective casting around one of the upstream gears which I think must be to prevent you graunching it when messing about with wheel combinations. |
