John Slaven | 15/01/2019 21:46:57 |
![]() 27 forum posts 17 photos | Hi All, My WM250 seems to have a very loose saddle. I can see no obvious gib adjustments. Is there some other adjustment for the saddle that I have missed? Any help would be much appreciated. Cheers the noo John. |
mechman48 | 16/01/2019 11:12:09 |
![]() 2947 forum posts 468 photos | I have a 250V-F too... this happened to me, have a look at the back of the saddle, under the shear, you should find a metal 'gib strip' held on by bolts these may well be loose, give them a snug up , it should fix the problem. |
Howard Lewis | 16/01/2019 11:14:49 |
7227 forum posts 21 photos | If there are no obvious gib strip adjusters along the side, there may be a large screwdriver slotted item on the end, under the handwheel. This will drive a wedge onto the gib to take out slack. They do work loose and increase slack and so need resetting from time to time.. Howard |
mechman48 | 16/01/2019 11:17:45 |
![]() 2947 forum posts 468 photos | Just had a look at my manual, the item I mentioned is part # 63 on the carriage assembly page. |
John Slaven | 16/01/2019 11:18:49 |
![]() 27 forum posts 17 photos | Hi George and Howard, Thanks for the reply. I'll have a look this afternoon. The saddle is pretty loose and parting off is near impossible. Cheers the noo John. |
mechman48 | 16/01/2019 12:48:09 |
![]() 2947 forum posts 468 photos | Just on the off chance check the 4 SHSC that fasten the cross slide to the saddle gear box, they may have also worked loose enough to give it slight lift...? |
John Slaven | 16/01/2019 15:54:08 |
![]() 27 forum posts 17 photos | Hi All, Thanks for the replies. George, you were right. The 4 allen bolts at the back of the saddle were loose. Gave them a snug up and the saddle feels a lot better. I can now part with confidence! Cheers the noo John. |
mechman48 | 16/01/2019 23:16:21 |
![]() 2947 forum posts 468 photos | |
