Martin Cargill | 25/11/2018 17:53:10 |
203 forum posts | I have a un-named 8" horizontal rotary table. The centre of the table has an M12 screw thread, and it also has what looks like a very big screwdriver slot running across the centre (either side of the threaded hole). I'm just trying to work out how I centre the table to my mill. Is the part I can see in the centre likely to be a screwed in plug of some kind? Is there a chance that there is a morse taper in the centre of the table. Any suggestions would be helpful. Martin
Jon | 25/11/2018 20:11:43 |
1001 forum posts 49 photos | Had a look around for images but havent seen any with what appears to be a small M12 hole. Usually a lot larger to accept MT2 or more likely MT3 with an internal M12 thread in the collets. Certainly the slots are for tensioning end float but usually on underside. There should be numerous T slots to use as fixings. Using MT as a means of centring isnt accurate in the slightest, its just the easy way out. |
fishy-steve | 25/11/2018 20:34:41 |
122 forum posts 30 photos | Hi Martin, Criterion rotary tables had a removable centre that had a slot cut through the centre to make removal easier. They were screwed in. Unfortunately on removal there was no morse taper cut in the bore. Steve. |
Martin Cargill | 26/11/2018 17:33:27 |
203 forum posts | Thanks for the replies. I think my table sounds like the Criterion that you describe. I have a cheap 4 jaw chuck (quite a flat one) that I can fit to it (just need to drill 4 holes in it and make some spacers to hold the chuck high enough to clear the threaded boss on the back). I should then be able to centre the table to the mill using a large ball bearing sat in the centre of the chuck and lined up with the MT3 vertical head in the mill (or use a wiggler ). Then I can centre the chuck to the table using a DTI. Martin |
Les Jones 1 | 26/11/2018 17:43:22 |
2292 forum posts 159 photos | If it is a 4 jaw independent chuck there is no need to centre it precisly on the rotary table. Les. |
