tich
regulator
Philip Burley16/10/2018 12:22:14
198 forum posts
Hello , I am about to start to make a regulator for a big boiler Tich , I would like to make a screw down type as it looks simpler . Has any one any experience of one ?. I have seen several drawings , but they all seem to be drawn by people who know what they are doing for people who know what they are doing . Any fully explained designs available for us beginners ?
regards Phil
paul rushmer16/10/2018 15:23:15
104 forum posts
17 photos
Hi Phil
The regulator in Robroy is screw down and mine works a treat, seals well for boiler tests. Just do not leave it tight shut as the boiler cools down you may not be able to move it until the boiler is hot again.
hope this helps Paul
Philip Burley16/10/2018 18:26:35
198 forum posts
if I can blow up that drawing for one off a Firefly it would probably be ok . Problem is how to enlarge it !
Jeff Dayman16/10/2018 21:29:08
2356 forum posts
47 photos
Philip, does your local library or school still have a photocopier? If so you can enlarge a dwg on that. Also can do it with a scanner and some kind of photoshop type tool on a PC.
Philip Burley17/10/2018 05:42:47
198 forum posts
I only have the drawings on here , I will have to try and print them off and enlarge them . But has anyone made a screw down regulator for a Tich ?
David Wasson17/10/2018 10:12:02
149 forum posts
43 photos
Hi Philip,
I have not made a regulator for a Tich, but, I have made a screw down regulator that works quite well. Here's a link to a post here on this forum about screw down regulators including several photos and drawings:
David
Another JohnS17/10/2018 21:05:29
842 forum posts
56 photos
Philip;
I made a screw-down regulator for my large-boilered Tich. I did this back in the early '90s, and it has worked flawlessly.
I patterned it off of the Rob Roy one, used a coarse 1/4" tap and the valve end something like 45 degrees. I probably scaled it down to fit the regulator tube so as to fit in with the LBSC regulator bushing design.
Do it!
Sorry, no pictures, no drawings. It's never been out since first steaming.
John.
