Perforated copper sheet
Andy Lawrence 203/10/2018 20:40:37
3 forum posts
I am trying to obtain a small quantity of perforated copper sheet ,so far without success. Does anyone know of a supplier in the UK
JasonB04/10/2018 08:34:33
Andy, could you give an idea of the type and size of perforations, thickness of sheet and what you would call a "small Quantity" and use as this will help people come up with more suitable suggestions.
John Haine04/10/2018 08:51:44
5563 forum posts
322 photos
And the application? Depending on this other materials may be used that are available, for example for emi shielding.
Andrew Johnston04/10/2018 09:27:18
7061 forum posts
719 photos
A quick search brings up a number of companies advertising perforated copper sheet. So what's special about the application that it can't be met by the available sheets?
Andy Lawrence 204/10/2018 19:21:24
3 forum posts
Thanks for your replies.I have located several suppliers who stock the item I'm looking for(copper perf plate 0.7mm thick .5mm hole.pitch 7mm) The problem is that they only supply in 1x2 meter plate size,and since I make Microphones this would keep me going for a very long time,apart from costing £200.! I need about half a meter sq.
Robert Atkinson 204/10/2018 19:39:06
1891 forum posts
37 photos
Look at a laser cutting firm like LaserMaster not only will they cut the holes in plain sheet they will cut the outline shape too. You could even try fancy hole shapes or patterns. Cost is generally quite reasonable.
https://www.lasermaster.co.uk/materials/brass-copper
Robert
Andy Lawrence 204/10/2018 20:34:06
3 forum posts
Thanks Robert,I'll give them a try.
