Is this the worst-ever substitute for a drop of Loctite ?
Other contenders are invited ...
Michael Gilligan29/09/2018 21:42:54
23121 forum posts
1360 photos
I am trying to rebuild a small air/vacuum pump
It's like a mains-powered version of the popular tyre inflator, and was rather better built. ... until someone had a go at fixing it.
The big-end bearing appears to have about +/- 10 degrees of angular play, but most of that is in the housing !!
A few drops of Loctite 'Bearing Fit' would probably have fixed the original problem ... BUT the genius technician decided to do this instead:
crying 2 ... Yes, folks ... it's been 'staked' or 'peened' ... or some-such ... crying 2
This is going to be an interesting restoration
Edit: for scale ... the bearing is 1/4" bore
Edited By Michael Gilligan on 29/09/2018 21:46:21
Mike Poole29/09/2018 23:08:04
3676 forum posts
82 photos
Smashed?
larry phelan 130/09/2018 10:07:57
1346 forum posts
15 photos
Nothing really wrong there,it,s just a different approach,they call it GUNTERING
SillyOldDuffer30/09/2018 10:31:02
10668 forum posts
2415 photos
Posted by larry phelan 1 on 30/09/2018 10:07:57:
Thanks Larry - another new word learned. I must remember not to use it in front of mother...
Howard Lewis30/09/2018 12:24:58
7227 forum posts
21 photos
Looks a bit thin in the wall to bore and bush. Brass shim perhaps?
Or machine a replacement from solid, then you'll know that it's right.
