Ultra Miniature 3V E10 Indicator Light Bulb Needed
Martin King 206/09/2018 10:06:29
1129 forum posts
Hi All,
Have tried everywhere to find one of these tiny bulbs:
The diameter of the screw part is 5.25mm; the length of the bottom metal part is 9mm from the rim to the bottom contact; runs off 2 AA cells.
It is for the indicator lamp on an old torque wrench tool.
Tried RS, FARNELL etc but no go, any thoughts please?
Cheers, Martin
KWIL06/09/2018 10:15:12
3681 forum posts
70 photos
for a start
pgk pgk06/09/2018 10:56:32
2661 forum posts
294 photos
If really stuck for a solution then diagnostic set bulbs from the like of heine or welch allyn might be adaptable since their screw end is generally smaller than the bulb base.
pgk
John Baron06/09/2018 10:58:52
520 forum posts
194 photos
Hi Martin,
That bulb sounds like the old Christmas tree light string bulb !
Since you have the old bulb, why not just pop a LED into the old base. You might need a resistor to current limit for the LED. If I remember correctly, a Yellow LED is about 3 volts.
Neil A06/09/2018 11:02:31
160 forum posts
You might find what you need at "Rapid Electronics", they have a fair selection.
Just search for E10 MES lamps.
Edited By Neil A on 06/09/2018 11:04:33
Grindstone Cowboy06/09/2018 11:59:36
1160 forum posts
73 photos
I think you are looking for an E5 LES type
Similar to **LINK**
But that's a 6 volt one - it would still work though.
Martin King 206/09/2018 15:29:31
1129 forum posts
Thanks very much guys, will check those out.
Martin
