GHT Drive Belt Material
merlin08/07/2018 21:07:36
141 forum posts
Many years ago I made a George H. Thomas Universal Pillar Tool which has stood on the shelf for some years. I now want to use it and have found the 5mm diam plastic belt to be broken and crazed.
Do members have any advice on a good modern material to use: I expect to have to use a soldering iron to make the join.
Thanks,
Ted
Clive Brown 108/07/2018 21:23:10
1050 forum posts
56 photos
Look for round polyurethane belting. Widely available, eg try ebay.
IIRC, mine is 5mm. dia.
It's worth taking a little trouble over joining. Heat a suitable piece of mild sleel, hold both ends in flat contact with it for a few seconds, then push together firmly. Takes a bit of a knack to get the joint well aligned, but practice make perfect!
Should add that cutting the ends as square as possible with a sharp blade aids a good join.
Edited By Clive Brown 1 on 08/07/2018 21:44:59
Michael Gilligan08/07/2018 21:45:58
23121 forum posts
1360 photos
The material at ebay item 302149867073 is excellent quality, and very reasonably priced.
... Alternatives are, I'm sure, available.
merlin08/07/2018 22:04:19
141 forum posts
Thanks for the advice
Ted
Paul Lousick08/07/2018 23:11:37
2276 forum posts
801 photos
O-ring cord is available in different diameters. It is cut to length and the ends are joined together with Loctite 406
Paul
