scrollsaw blades.
mick7001/07/2018 12:19:29
524 forum posts
38 photos
any recommendations for for scrollsaw blades now i have this one sorted and working properly?
TPI useful as well
mainly for cutting branches up to 50mm into discs approx 5mm thick for pyrography projects for kids.
they will be dried before cutting.
blade length is 133mm if that makes difference
thanks.
Mike Crossfield01/07/2018 12:38:54
286 forum posts
36 photos
Mick
After trying lots of different makes with varying results, I now only use Flying Dutchman blades. I get mine from the US, but because the blades are light the shipping cost is not too bad. Delivery is surprising quick too. Take a look at www.mikesworkshop.com. Lots of useful info even if you don’t buy from him.
HTH
Dalboy01/07/2018 14:03:08
1009 forum posts
305 photos
Green wood will clog up the teeth in no time. Also how much clean up of the surface will you want to do before burning on to the wood. So go for a coarser toothed blade.
How long will you be leaving the branches before cutting as a rough guide it takes 1 year for every inch of thickness
If you have the use of a bandsaw then personally that would be my preferred option to cut them. Also another thing not to do with cutting is that as the wood dries depending on the wood it may all split. Grain is another factor when burning so check the branches to see if it is a close grained wood
I use quite a bit of green wood and also do a little pyrography
Edited By Derek Lane 2 on 01/07/2018 14:05:02
Cornish Jack01/07/2018 14:28:37
1228 forum posts
172 photos
+1 for Flying Dutchman
rgds
Bill
