Siemens Micromaster 420 VFD queries.
Andrew Tinsley09/06/2018 11:57:50
1817 forum posts
Hello,
Just starting to sort out a Micromaster VFD with the basic operating panel (BOP).
I assume that I can construct a remote pendant control for stop/start, alter frequency and jog, by directly connecting the pendant to the VFD? or are you restricted to doing this via the BOP?
I have yet to wade through all the operating instructions which I am sure will reveal what can and can't be done. However I usually get a headache when trying to sort out the instructions. There is so much stuff that I will never need and what I want is usually the last place I look!
Thanks,
Andrew.
John Rudd09/06/2018 12:07:53
1479 forum posts
Yes, you can control the inverter via a diy pendant. Use the digital inputs configured as required, connect a 5k pot to terminals 1,2&3 and tell the inverter what you want to do.....
Andrew Tinsley09/06/2018 14:37:23
1817 forum posts
Thank you John,
Just a quick query, Can I instruct the VFD via the basic operating panel or do I need the advanced AOP panel?
Andrew.
John Rudd09/06/2018 15:40:40
1479 forum posts
My intepretation of the manual is that you can........of course , I stand to be corrected...
Andrew Tinsley09/06/2018 15:50:56
1817 forum posts
Thank you John,
I shall now take some Paracetamol and see how I get on!
Andrew.
John Rudd09/06/2018 16:28:19
1479 forum posts
Programming can be fairly straightforward, if you take your time and have the motor/inverter and manual in front of you....
Andrew Tinsley09/06/2018 16:51:04
1817 forum posts
Hello John,
It isn't the programming per se that I find complicated. It is trying to find the appropriate bits which one actually needs. I guess that is about 5% of the actual capabilities of the VFD, are the ones I want and I tend to get lost in the other 95%!
Really it serves me right, I should stick to one make of VFD and then setting up the second or third one is easy. I tend to buy VFDs that are good value and that means I never get the same type twice.
Thanks again,
Andrew.
Nick Hulme09/06/2018 17:03:01
750 forum posts
37 photos
Andrew,
The Siemens documentation is very good, you shouldn't have any problems,
- Nick
