Rik Shaw | 27/05/2018 13:19:01 |
![]() 1494 forum posts 403 photos | I have just been given this steady and told that it came of a WARCO lathe - model unknown. I have compared it to the fixed steady belonging to my BH600G which is 6" (150mm) centre height and it looks a little smaller. My guess is that it fits on a lathe of around 5" centre height or thereabouts. Does anyone know which model it is meant to fit? Rik Edited By Rik Shaw on 27/05/2018 13:29:39 |
richardandtracy | 27/05/2018 13:36:38 |
![]() 943 forum posts 10 photos | Looks like the one on my WMT 300. Was used on the WMT300/1 and /2. Has a 6" centre height, but as the cross slide was used for milling, it's a bit thicker than normal. Regards Richard Edited By richardandtracy on 27/05/2018 13:40:56 |
Rik Shaw | 27/05/2018 16:42:00 |
![]() 1494 forum posts 403 photos | Thanks for that Richard. If you get a minute could you measure the approx distance from the tip of the brassy noses to the centre of the fixing holes for me? I make it about 144mm. Thanks in advance. Rik |
richardandtracy | 27/05/2018 17:59:36 |
![]() 943 forum posts 10 photos | Top one, Min 138, Max 160 ish. Hope that fits. Regards Richard.
Rik Shaw | 27/05/2018 21:07:05 |
![]() 1494 forum posts 403 photos | Richard - your dims tie up exactly. Thank you for taking the trouble. ATB Rik
richardandtracy | 27/05/2018 21:20:10 |
![]() 943 forum posts 10 photos | As the Warco is the combi machine, it'll also fit a Clarke CL500, CL430, Sealey SM27 etc.. But not the Chester Model B where the centre height is bigger. Regards Richard.
