Thomas Dye | 11/04/2018 17:03:19 |
9 forum posts | New member. Looking to eventually acquire a lathe and/or milling machine, when I accumulate the budget, that is. |
Neil Wyatt | 11/04/2018 18:47:51 |
![]() 19226 forum posts 749 photos 86 articles | Welcome to the forum Thomas, What sort of projects do you have in mind? Neil |
Thomas Dye | 11/04/2018 18:53:42 |
9 forum posts | Hi Neil, My current projects are: a reflow soldering oven; a CNC router controller; and a SCARA based pick and place robot for electronic components. If I had metalwork tools I would use them to make more tools! |
Mick Henshall | 11/04/2018 20:10:19 |
![]() 562 forum posts 34 photos | There are some very knowledgible (have I spelt that right 🤔 )people on here I have been helped a number of times and have been very grateful Mick |
Thomas Dye | 11/04/2018 20:40:32 |
9 forum posts | Edited By Thomas Dye on 11/04/2018 20:42:31 |
george Aldous | 13/04/2018 15:02:41 |
17 forum posts | welcome Tom I'm in dover. George. |
Neil Wyatt | 13/04/2018 19:36:50 |
![]() 19226 forum posts 749 photos 86 articles | Looks interesting Tom, what printer are you using? We have a 3D printer topic (we aren't as old fashioned as you might thinkl!) Neil |
Thomas Dye | 13/04/2018 20:52:05 |
9 forum posts | Hi Neil, I will be using my anet a8, it's a prusa i3 clone with an aluminium backed heated bed and z leadscrews. |
Thomas Dye | 13/04/2018 21:06:18 |
9 forum posts | In my SCARA each arm is over 200mm long so, to get better positional resolution I decided to use an 18:1 worm drive to reduce the whole step angular resolution to 0.1?. Obviously I have no idea whether the design will actually work, nor whether backlash will overwhelm the designed angular resolution. But, I wanted to check if anyone thought that the speed of the arm would be sufficient even with the 18x reduction. |
Neil Wyatt | 13/04/2018 22:15:21 |
![]() 19226 forum posts 749 photos 86 articles | I've no experience of implementing SCARA, but Joseph Noci is building a morgan style 3D printer and documenting it in another thread here which may have some issues in common? N. |
