Fig 36 Page 26
Andrew Moore 6 | 07/03/2018 20:23:17 |
8 forum posts 1 photos | Please can somebody explain what the circled numbers refer to (numbers 1 to 8, excluding 6!). Thanks |
Michael Gilligan | 07/03/2018 21:03:06 |
![]() 23121 forum posts 1360 photos | Good question, Andrew They seem to have shuffled the numbering that was allocated on page 25 MichaelG.
Rick Kirkland 1 | 07/03/2018 21:41:28 |
![]() 175 forum posts | Andrew, the photo, fig 35 on page 25 has no connection with the 3 diagrams in fig 36, page 26 other than to indicate what each part is according to the numbers in brackets below the photo fig 35 at the bottom of page 25. The first diagram 1. on fig 36, page 26 is a simple gear train and should be read in connection with the screw cutting set up charts, figs 37 and 38 on page 27. basically 1 in fig 36 shows 2 as the driver, 7 as an idler, 1 is simply a spacer gear to fill the empty space on the stud and 4 is the driven or leadscrew gear. If you read the diagrams 2 and 3 in fig 36 in conjunction with the charts it's all pretty self explanatory. The numbers 1,2 and 3 in the diagram boxes refer to the end column marked "set up". The circled numbers show the relative gears and positions taken up on the studs to provide simple or compound reduction train set ups, hence the side views of the banjo indicating with dotted lines the gears 'behind' gears. You'll notice that certain trains require the leadscrew gear to be on the inboard or outboard end of the leadscrew depending on the train type requirements. Simply move the spacer from one side of the leadscrew gear to the other. |
Michael Gilligan | 07/03/2018 23:38:38 |
![]() 23121 forum posts 1360 photos | Posted by Rick Kirkland 1 on 07/03/2018 21:41:28:
Andrew, the photo, fig 35 on page 25 has no connection with the 3 diagrams in fig 36, page 26 other than to indicate what each part is according to the numbers in brackets below the photo fig 35 at the bottom of page 25. . But it fails to do that. MichaelG. |
Robbo | 08/03/2018 16:17:51 |
1504 forum posts 142 photos | Andrew If you can access a Super 7 Manual and look at the corresponding pages, the diagrams are much more easily understood, as they do away with this numbering and refer directly to "1st Stud, 2nd Stud, Leadscrew, Driver" etc which directly relates to the tables. I would scan the page in, but we have recently been attacked by malevolent gremlins (probably the Russians) and the computer is gradually being put back to work, so no scanning just now. It is hugely frustrating! If you are in the Myford Yahoo Group there is an old S7 manual in the files section, probably in the last file, which is actually a folder with several files in it. |
Andrew Moore 6 | 08/03/2018 18:47:06 |
8 forum posts 1 photos | Thanks everybody for your replies.Regards Andrew
