John MC | 14/02/2018 16:08:36 |
![]() 464 forum posts 72 photos | I have a Fowler-Bowers internal micrometer, 0.50" to 0.62" range, the type with 3 expanding pins. While it is accurate to the various setting rings I have, the scale on the thimble does not quite line up with the scale on the sleeve, if that makes sense, enough to cause a reading error unless I am careful. On an external micrometer this type of error can usually be corrected by moving the sleeve axially with a tiny C spanner. I've looked at the manufacturers website, it explains resetting the thimble to a gauge but not resetting the sleeve. Its bound to catch me out one day so I would like to reset the sleeve,anyone know how? John |
ronan walsh | 14/02/2018 16:44:29 |
546 forum posts 32 photos | Can you not send it back to the manufacturer for calibration ? Might be the easiest way to do it. |
vintagengineer | 14/02/2018 19:52:59 |
![]() 469 forum posts 6 photos | I will have a look at mine tomorrow. Have you tried unscrewing the the thimble? I think there is an adjustable ring under the thimble.
