which shaft is which
dw dw 1 | 13/02/2018 14:24:25 |
40 forum posts 15 photos |
Kettrinboy | 13/02/2018 19:12:13 |
94 forum posts 49 photos | The 127 will go on the bottom , 60 idler on the middle and 70 on the top stud , the tail end sleeve should unscrew so you that you can then fit a bigger gearwheel on the top stud , well at least mine does , ive only needed to do it once to get an 85t wheel on. regards Geoff |
dw dw 1 | 13/02/2018 19:56:02 |
40 forum posts 15 photos | Many thanks Geoff, this is a new lathe for me so didnt realize the end sleeve was removeable, when I offered up the 70t cog it was obvious it wouldnt fit. Took off the end sleeve now the 70t cog fits as do the other 2 cogs. So all ready tomorrow to try my first screwcutting. As an aside what is the point of the tail end sleeve, I know another beginners question. Rgds DW |
not done it yet | 13/02/2018 20:51:53 |
7517 forum posts 20 photos | It will direct any swarf, which goes through the spindle, away from the gearing. |
dw dw 1 | 14/02/2018 09:52:05 |
40 forum posts 15 photos | that makes sense so need to put it back as soon as screwcutting is finished. Or work out another arrangement of cogs! |
