Member postings for dw dw 1
Here is a list of all the postings dw dw 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: harrison L5 screwcutting
14/02/2018 09:52:05
that makes sense so need to put it back as soon as screwcutting is finished. Or work out another arrangement of cogs!
13/02/2018 19:56:02
Many thanks Geoff, this is a new lathe for me so didnt realize the end sleeve was removeable, when I offered up the 70t cog it was obvious it wouldnt fit. Took off the end sleeve now the 70t cog fits as do the other 2 cogs. So all ready tomorrow to try my first screwcutting. As an aside what is the point of the tail end sleeve, I know another beginners question. Rgds DW
13/02/2018 14:24:25
p1020445.jpgp1020440.jpgI am about to cut my first thread on my newly acquired L5. To cut 1.75metric thread I need 70 top shaft, 60 intermediate shaft, 127 bottom shaft. Can someone tell me which shaft is which I iknow this is a beginners question but I cant work it out. If the top shaft is logically the one with the small cog in pic (below) the 70 cog wont fit because it fouls the tail end sleeve.
Thread: Harrison lathe clutch
04/02/2018 12:20:48
looks like the 55 deg whit 12G was a one off used on this lathe. Have now found some on ebay. Cheers all.
DW.
01/02/2018 14:19:26
Posted by Brian Wood on 01/02/2018 11:21:18:
I think I can understand why the piece of wire was put in---some crisis arose in the middle of an urgent job and this made a working fix to get the job running again without having to tear down the spindle to fit it.
A 'bodge' that kept the machine running and the sort of solution a busy machine shop would come up with.
If that is correct then a washer of the same thickness as the wire will be a suitable replacement, the remaining unknown would be it's stage of hardness
Thanks Brian. I made a washer same thickness. Then I looked again at the parts drawing the washer (36) is between bearing (30) & cluch plate (28) so the wire is actually the wrong side of the pulley. The bearing cage is broken in one place (ordered replacement) so am now ondering if the wire was put there to stop bearing falling out??
01/02/2018 14:12:49
Posted by norm norton on 01/02/2018 10:11:51:
I would just try a washer that approximates in thickness to the piece of wire. The previous user might have put it in to compensate for wear and to get back some adjustment.
You need to go to the Harrison Yahoo site with this question where there are people with specific Harrison knowledge, and there is even a current thread on the L5 clutch! **LINK**
Norm
Thanks Norm, just joined. All the best DW.
31/01/2018 11:17:18
31/01/2018 11:14:25
31/01/2018 11:11:49
31/01/2018 11:11:26
31/01/2018 10:47:24
Hello all, hope someone can help. I have just taken apart the clutch mech' on my Harrison L5 lathe (see pic). Between the halo disc (28) & the R.H. clutch plate (27) the previous owner has put a piece of thick wire bent into a circle (see pic) as some kind of washer/spacer. I have the washers that adjust the clutch slip (36) but (37) washer for L5A is not there, I am wondering if the wire spacer has been put in as replacement in error for washer (37) which is present on L5A clutch?Has anyone got any info on this wire spacer or a photo of their clutch mech' or a link to a different parts drawing.All the best DW.
Thread: Harrison gear box
22/12/2017 09:23:15
Posted by Robbo on 21/12/2017 19:14:21:
Posted by dw dw 1 on 20/12/2017 15:02:34:
yes I did mean the headstock as it seems to sit on a bed like the lathe bed so was wondering if it slides off, so was looking for a workshop manual diagram to see how its all held together.
May be one like this? The "it's here" refers to the oil sight glass someone was asking about in an earlier thread.l5 headstock - 001 (custom).jpg
Yes thats it, thanks for your time. All the best DW
21/12/2017 16:42:42
Posted by Paul Kemp on 21/12/2017 10:00:23:
dw,
I had a similar problem this year moving a Harrison L6 and I had the same reservations. It was also in a small shed in a garden (lawn) that was about 50' from the house, up hill from the house. There was a passage way between the houses little wider than the machine itself and a step from the lawn to the hard surface of the passage way with a drain right on the corner. At the front of the house the path went straight out onto the road (no front garden). I looked at lifting the lathe off the cabinet but was advised that if I did the seals between the two are difficult to refit and would likely need replacement. They are there to stop coolant / cutting oil getting down to the motor. I also looked at removing the motor but as pointed out by someone else earlier in this thread it adds useful weight to the base for transport as lathes are a little top heavy! Solution was to get some help from two good friends one with considerable experience of moving machines and an engine crane, the other having a plant trailer.
We extricated the machine complete less the chuck and any loose equipment. First step was to use a decent bar to lift it on blocks to remove the feet inserted in the bottom of the stand - from the bottom! Next it had to be turned 90 degrees to be rolled out of the door. Small rollers like 1/2" or 3/4 water barrel are a lot better than large ones like scaffold tube I found. I purchased a sheet of 3/4" ply split down the middle to give 2 pieces 2' X 8'. One was placed outside the door of the shed (about 4' from the boundary) so parallel with the shed and the machine had to be turned 90 degrees again as soon as it came out of the door! I then secured a pull lift with some long strops to a handy anchorage and this was used in conjunction with the rollers to lower it across the lawn down the slope, transferring the ply as we went. We then used small lumps of timber and one piece of ply to bridge over the drain and the step at the end of the lawn, keeping the weight on the pull lift to stop it rolling down out of control until on the flat of the passageway then just pushed it on the rollers down the passageway (very little effort required) until it was out in the road. We then slung it around the bed (important to wind the carriage towards the tailstock and have the tailstock at the end of the bed for balance) and lifted it with the engine crane, backed the plant trailer under, landing it on the rollers again and rolling it forward to balance the trailer. Then lifted with a bar and blocks of wood to remove the rollers, ratchet strapped it down and away. Took about 3 hours start to finish. No issues with the 10 mile journey and then put it back on the rollers, built a ramp with the ply and secured the pull lift to the trailer drawbar and lowered it down the ramp straight into the storage facility.
The important things are, work slowly and steadily, have a good plan and the necessary equipment before you start (rollers, timber packing of various thickness, couple of decent crow bars, pull lift perhaps, strops or decent rope) and be ready to change or adapt your plan as things progress. The fellow that was with me has moved his Bridgeport from house to house at least twice on his own so even on your own it can be done! I would advise you get a couple of willing and sensible people to give you some help though. However if you can't get sensible steady people you are probably best off doing it on your own, willing bulls in china shops make it more difficult and more dangerous!
Good luck.
Paul.
Thanks paul for the time & effort to write this, I had cut up some scaffold tube but will now take your advice & use water pipe. all the best DW.
21/12/2017 09:16:23
Posted by David Standing 1 on 20/12/2017 15:10:07:
Where do you need to move the lathe from, and to, and are there any particular hazards/issues involved?
The Egyptians allegedly built the pyramids with manual labour, wedges, levers and pulleys etc., there's lots of ingenious methods available to us thousands of years later.
I moved a 480kg Boxford from Liverpool to my garage 240 miles away a few months ago, along with many other machines over the last couple of years I have shifted in and out.
The Boxford went on four heavy duty castors, on and off a Luton van tail lift, and I could push it in the garage on my own.
I have moved all sorts of heavy stuff with castors, levers, rollers, and my hydraulic engine crane.
I am not a fan of stripping any machine more than I have to, particularly something like a headstock, or anything that will involve having to set it up again afterwards (apart from levelling, which is inevitable).
As below, problem is its in a small garden shed & its only little old me moving it. I have cut down a scaffold pole to use as rollers but would welcome ideas on how the althe is taken off its cabinet base.
21/12/2017 09:14:00
Posted by Jon on 20/12/2017 15:47:43:
If your moving it 30 or 40 yards at one location just use scaffold as rollers only need 3. Soon as lathe rolls off last roller move it to the front and so on. Its a one handed operation fully laden sub 3/4 tonne.
Very easy to lift with a short bar just prise it up and insert a wedge under. Much newer M300 are a right pain to move even with a 5ft crow bar.
When i scrapped the much newer 140 8 yrs ago it took 3 of us to push it up a ramp 4ft long rising to 20" high , started digging in - no pulleys, just the tail stock removed and chucks but retained the coolant.
problem is I have to move it on my own (& not as young as i was) its also in a small space, garden shed, so want to take as much weight off as poss'. I would rather reset it up again after taking base off etc as realistically/practically thats the only way I can move it.
20/12/2017 15:02:34
Posted by Alan Waddington 2 on 20/12/2017 11:55:28:
The quick change gearbox on an L5 weighs next to nothing, so i'm assuming you are talking about removing the headstock?......i wouldn't. The manual also advises against removing the lathe from the cabinet as the two were accurately shimmed at the factory.
An L5 is dead easy to move on rollers as the base is in one piece, and as bigger lathes go they're not that heavy.
I got one in the back of a Renault Master by nailing an angle iron to the end of two long planks and attaching a chain block to the angle, lathe was slowly pulled up the planks on 20mm rollers until it reached the tipping point and dropped nicely in the back of the van. Reversed the procedure at the other end.
Personally i wouldn't remove the motor either, as it's low down and helps counter the top heavy lathe's natural tendency to want to fall over.
Edited By Alan Waddington 2 on 20/12/2017 12:01:00
20/12/2017 15:00:23
Posted by Ian S C on 20/12/2017 11:34:45:
You can probably drop the motor out, that's a few kilos.
Ian S C
yes was thinking that as well as the tailstock & cross slides
20/12/2017 14:59:25
Posted by fizzy on 20/12/2017 10:55:07:
I moved mine last year - three of us, some thick wall tubing to roll it on and its not so bad. I removed most of the saddle and not much else. Im pretty sure you cant remove the gearbox as its all part of the same casting, but i might be wrong.
I was looking at the headstock/gear train ass' & it sits on a notched bed the same as the lathe bed so was wondering if it slid off like the tailstock can slide off the bed?
20/12/2017 10:08:23
Hello all, I am trying to move a Harrison L5 lath, I hope to remove the gearbox to make it easier. Can anyone tell me how to remove the gearbox or give me a link to a manual or parts diagram to help?
All the best DW.
Thread: morse taper
18/10/2016 16:01:56
Clive there is a center in the drill end but I am confused as to where the drill goes, in the chuck or in the tailstock (cant fit it in tailstock as drill has 3MT end)?
Rgds Dw.
