Mike Suffolk | 05/01/2018 17:56:19 |
8 forum posts 4 photos | Hi Folks, I'm new to clocks, have recently started the John Wilding scroll frame clock and already need help. In my book (2002) the drawing of the fusee arbor shows the rear pivot as .225" dia while the front is .265" dia. I was expecting these to be both the same size to enable reaming both plates at once, and also to use a common size of reamer. Am i missing something? Can I make these .25"dia and wiz thru both plates with a reamer once I have depthed the great wheel with the centre pinion? Or, why are they marked as different sizes? And I haven't yet got to the old chestnuts of DP vs modulus cutters and wheel sizes (errors or not)! Scary stuff..... |
RJW | 05/01/2018 19:30:41 |
343 forum posts 36 photos | Hi Mike, the front pivot of the fusee arbour carries the grunt of the mainspring power during all operations, winding / running etc and bears the full load of mainspring power when fully wound and the chain against the fusee stop, it needs to be fairly beefy to carry the load otherwise it would chew the front plate hole oval very quickly, Hope this makes sense. John. Edited By RJW on 05/01/2018 19:35:40 |
Mike Suffolk | 05/01/2018 20:11:02 |
8 forum posts 4 photos | Thanks John, Yes that does make very good sense. My father made a couple of clocks and I remember him saying that he thought they worked because he wasn't very good at making good fits (I still think he was doing himself down). Unfortunately he is no longer around to ask and now I realise I should have paid attention when I had the chance. I feel happier about progressing the build again, so thanks for taking the trouble to reply, Mike |
Marcus Bowman | 06/01/2018 07:57:08 |
196 forum posts 2 photos | I agree with all that John says. These are running shafts, under a bit of load, so the holes should be tapered and burnished, and the shafts polished and burnished. A traditional method of lubrication would be to add a small oil sink on one side of each of the frames (the outside, usually). Adding an oil sink at the front would mean it was quite visible, and, on this kind of clock, you may not wish to do that. The BHI Journal recently had an interesting article and discussion about oil sinks on the inside of the frames, a method which has been found on some existing clocks, and prompted some debate. I'm not so sure they would be sufficiently accessible there, or that the oil would not be smeared out of the sink by end movement of the fusee shaft, in this clock. There has been some discussion, on this forum, about the shape of the back cock; and a discussion, too, about the gearing (DP or module sizes). My book is a 1998 edition, so you probably have a more up to date version. Lovely clock, and a nice project. Marcus |
RJW | 07/01/2018 20:36:49 |
343 forum posts 36 photos | My pleasure Mike, I've learned a ton of stuff on here over the years, so it was nice to be able to help with something I actually know about, I'd suggest not getting too hung up over the pivot sizes, if you cut them a bit small or even slightly over size if you're afraid of overcooking things it isn't a big deal, it's always a moveable feast on clocks because whatever pivot sizes you end up with you will always cut the holes to suit each individually, you'll be drilling the initial holes under size anyway in order to broach them to suit the pivots, so personally I'd make all the arbours and pivots first then drill the plates Another tip I would give, is to avoid cutting a sharp root where the pivot blends into the arbour, if it's cut sharp it'll create a stress raiser, and can guarantee if the clock ever suffers a mainspring or line break, that's where something is likely to break, best to cut the fillet with a small radius for the strength, which brings me to a point Marcus made, Totally agree with what Marcus wrote, but where oil sinks are concerned I personally would add them front and back (outside only) because they do tidy the job up no end, that's just my preference though but there are other reasons for my thoughts on this, Regarding oil sinks on the inside of the plates, some may advocate it but I don't, they further reduce the depth of the pivot hole and the pivots suffer less support = wear, they will also cause an excess of end shake on associated arbours, Most of all though, don't rush it and enjoy making that clock. John |
julian atkins | 07/01/2018 21:39:34 |
![]() 1285 forum posts 353 photos | Hi John, Thank you for the above very helpful posts and detail. One of the most interesting and informative series of posts I have read on this forum. Mike, good luck with the clock! Cheers, Julian |
Mike Suffolk | 09/01/2018 09:27:58 |
8 forum posts 4 photos | Thanks to all for the replies. When I decided to make a clock I thought I was going to be dealing with more model engineering - now I begin to think I am delving into black magic. Its certainly different to things I have tackled before. But, the comments I see help to back up other information and I think I am getting more of a feel for the job now. As for not rushing it John, there is not much chance. I read the book, go to the lathe, return to re-read the book - and so it goes on. But I'm still enjoying it - I smile at something minor I have made, and then tremble at the thought of the complexities to come. Hopefully I'll get there. Mike |
RJW | 09/01/2018 10:18:38 |
343 forum posts 36 photos | Hi Julian, Many thanks for your kind comments, they were very much appreciated, Mike, I felt very much the same as you when way back in the 90's I first delved into repairing clocks and watches, but to be truthful, when you dig into them there's no real mystery or black magic at all, they're actually quite crude as mechanical devices, Just keep asking questions when you get stuck, it gives our grey cells a bit of exercise, Lol. John.
roy entwistle | 09/01/2018 10:30:05 |
1716 forum posts | Mike if I can add my tuppence worth. Don't make anything too tight, I was taught that if it dosen't rattle it won't work Good luck Roy |
Martin Kyte | 09/01/2018 11:09:07 |
![]() 3445 forum posts 62 photos | Feel free to use small roller bearings on the bottom end of clocks if you prefer. regards Martin |
