lug lord | 27/12/2017 18:15:45 |
![]() 60 forum posts 20 photos | I thread a lot of 8mm stainless 316 did a bar today and i noticed the 1st cm of the thread is just mashed like its been ground down the nut just slips over the end . I had to cut this off and re cut a chamfer on the thread afterwards is this because maybe chasers are not sharp enough cant figure out whats gone wrong.
the rest of the thread was ok just that 1cm was no good almost like a mm had been turned off the end
thanks |
Nick Hulme | 30/12/2017 21:26:23 |
750 forum posts 37 photos | It sounds like it didn't initially feed correctly and because of that stripped off material down to the base diameter of the thread. - Nick |
lug lord | 30/12/2017 22:01:14 |
![]() 60 forum posts 20 photos | i use a chamfer tool to cut a neat chamfer on the end of the bar . I think maybe next time i will cut a lighter cut on the first pass then re adjust for a final cut see how that works out |
lug lord | 30/12/2017 22:01:52 |
![]() 60 forum posts 20 photos | i have also changed the chasers for what look like sharper ones |
JohnF | 31/12/2017 11:03:05 |
![]() 1243 forum posts 202 photos | Hi don’t forget there is a roll over lever on your die head so you can take a 1st ans 2nd cut no adjustment between cuts is necessary John |
lug lord | 31/12/2017 11:25:17 |
![]() 60 forum posts 20 photos | cheers yes i do use the lever but i might try taking lesser cuts 1st pass .my chasers are not the correct rake for stainless steel so might be hard on them i believe i should use am5 or as but i am just using the standard s20 |
