A milling slide support cage
Ady124/11/2017 08:50:35
6137 forum posts
893 photos
This started as an acorn and is turning into a major work in progress, I don't like milling btw and have no milling machine aspirations
but, sometimes we will have no choice in a project sooo...
Originally I welded some metal onto the bottom to try and improve things but that only highlighted a milling slides inadequacies
So I ground it off and went for a full wrap
The only damage to the slide is two 6mm holes in the base and two 8mm holes in the upper part of the back of the slide, no other harm was inflicted and the slide can be removed
The t-nuts are ski-nuts to make it easier to fit
All welding was done in situ so the fit is great
There are holes in the upper body so a hex key can reach down to the bolts
B+Q fencing provided the angle iron, 30mm mostly
The bottom swivelling part of the slide has been removed
You can see all my pictures in here
Edited By Ady1 on 24/11/2017 08:54:02
Ady124/11/2017 09:02:37
6137 forum posts
893 photos
So is it any good?
Well yes and no, it's obviously an improvement but now the vice is moving minutely instead of the slide
So I'm making a dedicated 4 point vice now, just for the slide, which will take me a while
All it's really done is move the eternal lathe milling problem somewhere else
So as I say, it's currently a WIP
Other points to note at the minit
The envelope is small, I would guess at 2-3 inches, that myford cross slide extension mod will be essential
I lost about 15mm in the vertical by removing the base to bring the bottom of the slide hard up against the cross slide with that 12mm bar
Edit: I'd also like to submit this item as my entry for the John Stevenson guffy welding award
Edited By Ady1 on 24/11/2017 09:14:52
Hopper24/11/2017 11:46:54
7881 forum posts
397 photos
Blimey, that's given the dancing vertical slide a good seeing to. It wouldn't dare get out of step now. Every time I use mine I swear to bolt the bottom of the vertical part directly to the cross slide. Never thought of the full orthopedic frame though. Certainly looks stout!
Neil Wyatt24/11/2017 15:46:59
19226 forum posts
749 photos
86 articles
Posted by Ady1 on 24/11/2017 09:02:37:
John and I discovered the RABA-WIWIT, so you can have this month's virtual RABA_WIWIT Award:
Eric Arthrell24/11/2017 17:19:23
47 forum posts
19 photos
Sorry Andy1 but I don't like it .
To weld in situ can cause stress related movement which can effect more delicate parts .Weld spatter can stick on slides , bad earth can track and trash motor and switches
Cast iron can and will snap/crack quite easily under stress
I would make it off the job clean it up and fit to the job.
Sorry to be negative
Eric
Ady124/11/2017 23:33:56
6137 forum posts
893 photos
That's OK Eric, I described it badly too
There was half a dozen tack welds on the lathe itself then the entire cross slide assembly was removed and taken to my welding and fabricating bit in the garage for the bulk of the work
Chris Trice25/11/2017 00:48:46
1376 forum posts
10 photos
I'm curious why you needed to make this. Traditionally you lock all the slides not in use which usually stiffens everything up.
Eric Arthrell25/11/2017 06:53:32
47 forum posts
19 photos
Andy1
you might find this site use full, I use it a lot. "http://www.mig-welding.co.uk/forum/".
Regards Eric
Ady125/11/2017 07:14:18
6137 forum posts
893 photos
Doesn't really work for many hobby lathes without a lot of effort to sort out tiny unwanted movements which can wreck a workpiece, especially for steel
This is an attempt to find a one shot solution to simplify milling on a lathe
