Bridgeport Mill BR2J Head Vibration
Vibration at lower speed
Absolute Beginner17/11/2017 17:41:32
103 forum posts
Just wondering if anybody else out there with a Bridgeport Mill noice any head vibration. ?
Mine is particularly noticeable at lower speeds. You can watch the light attached to the side of the column wobble.
It seems to reduce as the speed is increased from low 450 rpm upwards.
The head in itself dosent seem that noisy in fact it runs quietly I think......so just wondering if anyone else had come across the vibrations?
Or can suggest what might be causing it ?
Thank you
Gary
Chris Evans 617/11/2017 18:06:36
2156 forum posts
My machine had a slight tendency to do the same. Cured by mounting the machine on rubber pads, then used 2mm metal sheet as shims to level it.
Absolute Beginner17/11/2017 18:31:23
103 forum posts
Thanks Chris.
Good suggestion there. My machine is currently resting on a concrete floor, I did think about rubber feet but hadn't bothered. Perhaps that might help. Appreciate the suggestion.
Gary
Andrew Johnston17/11/2017 20:53:00
7061 forum posts
719 photos
Assuming a varispeed head then 450rpm is right at rhe bottom of the upper speed band. So one end will have the belt on the outside of the discs, and the other end has the belt on the inside of the discs, close to the drive shaft. Any corrosion or dents on the edges of the discs will cause vibration, as will the belt if it is contacting the drive shaft. I don't run my Bridgeport much below 500rpm on the top range; not so much due to specific vibration, but it just doesn't sound too happy.
PS: My Bridgeport just rests on a concrete floor
Edited By Andrew Johnston on 17/11/2017 20:53:35
Absolute Beginner17/11/2017 21:05:06
103 forum posts
Hi Andrew,
Interesting comments
Thanks
Gary
