Clive Brown 1 | 14/11/2017 15:01:10 |
1050 forum posts 56 photos | Hi, I need to solder 3/16" half-round brass beading along the top edges of the loco tender that I'm building. Since this stuff arrives as a coil, it needs to be straightened. The 2 main lengths will each be around 20", if it's not straight It will stick out like a sore thumb. Any tips for doing this will be much appreciated. TIA Clive |
Trevor Drabble | 14/11/2017 16:09:50 |
![]() 339 forum posts 7 photos | Clive , Suggest you have a look at a pyro straightener at your local electrical distributors or on line . BICC do a reasonable one . Trevor. |
JasonB | 14/11/2017 16:22:23 |
![]() 25215 forum posts 3105 photos 1 articles | Put one end in your vice, grip other end with mole grips and then give a sharp pull on the mole grips to stretch the beading taught, that should do the job |
Tim Stevens | 14/11/2017 16:24:47 |
![]() 1779 forum posts 1 photos | Jason beat me to it. A good trick for any wire less strong than music wire, in my experience. It would work with music wire too, but holding it is more difficult, pulling hard enough even more so. Cheers, Tim |
Clive Brown 1 | 15/11/2017 18:47:24 |
1050 forum posts 56 photos | Thanks for comments. The straighteners look surprisingly effective in the on-line videos, but I think I'll try a good strong pull. I'll probably need some mechanical advantage though! |
Martin Connelly | 15/11/2017 18:59:44 |
![]() 2549 forum posts 235 photos | If pulling does not work then try twisting it. One end in the headstock chuck and the other end in the tailstock chuck with a little bit of tension. Turn the chuck by hand. Martin C |
JasonB | 15/11/2017 19:47:24 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Martin Connelly on 15/11/2017 18:59:44:
If pulling does not work then try twisting it. One end in the headstock chuck and the other end in the tailstock chuck with a little bit of tension. Turn the chuck by hand. Martin C Does that work on half round beading? I've used it on round wire but would have thought the flat of the HR beading would end up in a spiral? |
Martin Connelly | 16/11/2017 19:22:03 |
![]() 2549 forum posts 235 photos | If you twist half round one way then reverse the twist direction it should straighten it but leave it flat. Just don't overdo the amount of rotation applied. Martin C |
