Is there an Air-Con 'leak detectorist' in the house ?
I need advice on fluids, please ...
Michael Gilligan01/11/2017 23:30:09
23121 forum posts
1360 photos
I have just purchased a small bottle of fluorescent test fluid.
https://www.ebay.co.uk/itm/60g-Green-Fluorescent-UV-Dye-Oil-Leak-Detection-Test-For-Car-A-C-Pipeline-Fuel/201985297748
I will be using this in some optical experiments, rather than for its intended purpose ; and I therefore need to know a little more about its specification.
Can anyone tell me, please, what Oil is used in such products, and how much it can reasonably be diluted.
My previouse experience with Fluoroscein is limited to sprinkling powder into underground streams. **LINK**
https://en.m.wikipedia.org/wiki/Fluorescein
Thanks
Brian Sweeting02/11/2017 00:01:25
453 forum posts
The oils used range from mineral oil, polyester oils and other esters.
Generally you added the the dye in minute amounts because it spread everywhere very quickly.
With refrigerant systems we didn't want anything in the system that shouldn't be there normally such as, no moisture, only oil and refrigerant.
Don't forget your black light detector.
Read this document for dosing etc...
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.advancedengineering.co.uk/wp-content/uploads/Spectroline-Refrigerants.pdf&ved=0ahUKEwiz1aCjy57XAhVDfhoKHSnADJgQFghdMAA&usg=AOvVaw1hPZkSFOcs0gq3JsuoUXRM
Edited By Brian Sweeting on 02/11/2017 00:04:10
Michael Gilligan02/11/2017 00:11:11
23121 forum posts
1360 photos
Thanks, Brian ... 'Minute amounts' sounds good.
So; do you think I could use 'most any oil with this fluid in an open vessel ?
... the light source is no problem, but the refrigerant gas isn't something I want to play with.
1. Just seen your edit yes
2. For info. I want a way of doing this sort of demo/test 'on the cheap'
http://meijitechno.com/maugc-uranium-glass-cube
Edited By Michael Gilligan on 02/11/2017 00:11:55
Edited By Michael Gilligan on 02/11/2017 00:36:49
