To etch or not to acid etch (primer paint)
Rainbows15/10/2017 01:00:17
658 forum posts
236 photos
Which scenarios is it good to use a first coat of acid etch primer as opposed to just using straight primer? Debating giving the new centec mill a paint job and have a tin of it I could use.
Neil Wyatt15/10/2017 01:07:56
19226 forum posts
749 photos
86 articles
I would use etch primer on difficult metals - alumnium, stainless, brass.
Steel loves paint and so does cast iron if it's properly degreased.
Brian John15/10/2017 07:51:10
1487 forum posts
582 photos
I use etch primer on all metals. I have also used it on steel and cast iron even if it wasn't necessary.
not done it yet15/10/2017 08:07:54
7517 forum posts
20 photos
As NW, surface preparation is very important. A rough surface 'key' and cleanliness are both requisites for successful painting. Both are important factors, as well as flatting for aethsetic reasons.
Ferrous metals need painting before oxidation, too, unless using an appropriate primer (but not necessarily an etching primer as per this posting) or paint (the old type Hunter's smooth- or hammer-rites). Knowing your actual metal surface is the key. Aluminium metal is very reactive in air and rapidly produces an oxide surface layer which is not conducive to good surface coating. Other metals may be the same, or keyless simply due to smoothness.
The one thing you do not do, normally is to use one top coat. This is because top coats do not usually combine with, neutralise, or penetrate, the surface layer on the substrate.
Following the instructions is therefore important when surface coating.
