Arduino Simulator?
Peter Bell | 29/09/2017 13:51:16 |
399 forum posts 167 photos | Is there a usable or useful Ardunio simulator that anyone has found or uses on the lines of the excellent PE6 which works with the Picaxe chips? Or is a simulator not really needed with Ardunio? Just looking around and getting all sorts of confusing signals for a beginner! Thanks Peter |
PaulC | 29/09/2017 15:25:18 |
1 forum posts 1 photos | I use Autocad's Arduino simulator Can be found at https://circuits.io Paul |
SillyOldDuffer | 29/09/2017 16:19:45 |
10668 forum posts 2415 photos | Not sure I can help much because I've never used one. They do exist. Many are aimed particularly at the Arduino but there are also simulators for the AVR chipset which the Arduino is based on. There are three reasons why I've not used a simulator:
If anyone can recommend a simulator I'd be pleased to hear of it. The main thing I miss on the Arduino is onboard debugging: I suspect it's not available for the Arduino simply because it's a hobby platform. Arduinos are not intended to replace the grown-up tools available for the AVR. Dave Edited By SillyOldDuffer on 29/09/2017 16:20:43 |
John Haine | 29/09/2017 16:23:36 |
5563 forum posts 322 photos | Given the low cost of an Arduino, why would you not just use the real thing? As the whole point of the Arduino is to control things, for a useful simulation you would need to provide physical I/O anyway which would cost as much or more! I'm reminded of the story in Gulliver's Travels about the country that decided to make a map of the whole territory at 1:1 scale. They found that it was rather too big to be convenient, wouldn't easily fold, and kept the sun and rain off the crops! So they decided to revert back to using the real place... |
Neil Wyatt | 29/09/2017 16:32:40 |
![]() 19226 forum posts 749 photos 86 articles | In fact it turns out that Studio 7 has native arduino support! Atmel Studio 7 features seamless one-click import of projects created in the Arduino development environment. Your sketch, including any libraries it references, will be imported into Studio 7 as a C++ project. Once imported, you can leverage the full capabilities of Studio 7 to fine-tune and debug your design. Atmel Studio 7 fully supports the powerful embedded debugger on the Arduino Zero board. For other Arduino boards, shield-adapters that expose debug connectors are available, or switch to one of the many available Xplained-Mini/PRO boards to fully leverage the Atmel HW eco-system. Regardless of what you choose, you will surely make something amazing. |
