identifying
Piero Franchi | 23/08/2017 07:59:45 |
124 forum posts 60 photos | Hi There Could do with a little help I have around five spare lead and cross slide screws for a lathe I am trying to identify
now can you tell if either of them are metric or imperial ???
Tony Pratt 1 | 23/08/2017 08:16:37 |
2319 forum posts 13 photos | The outside diameter should give you a good indication. Tony |
Piero Franchi | 23/08/2017 08:18:12 |
124 forum posts 60 photos | I am at home at the mo with only a steel rule, but it the one I am trying to identify does look closer to 15mm than any thing else.
John Haine | 23/08/2017 08:23:26 |
5563 forum posts 322 photos | Measure the length of 10 or even better 20 pitches along the screw with your mm steel ruler, then divide by the number of pitches you counted. Do this 3 times and take the average, even better. Diameter is not a good guide, e.g. 5/8 inches will look like 16mm if all you have is a steel rule. |
Tony Pratt 1 | 23/08/2017 08:27:07 |
2319 forum posts 13 photos | Well could be 15mm or maybe 9/16", if you want to sell them you will need to confirm the exact diameter & thread pitch. Tony |
Piero Franchi | 23/08/2017 08:30:56 |
124 forum posts 60 photos | The screw in question is a New old stock lead screw that came in a wax covering, it was in a Colchester light green hard plastic long bag (opened) the part number on the Colchester plastic bag reads 2155 I am looking to make sure the lead screw does indeed match the part number |
Nick Taylor 2 | 23/08/2017 08:55:16 |
102 forum posts | 2155 would seem to point to it being a metric crossflide feedscrew for a Chipmaster, at least according to my manual. It should be complete with nut. If only it was imperial I would make you an offer! |
Piero Franchi | 23/08/2017 09:04:03 |
124 forum posts 60 photos | It is complete with nut, I have two, one sealed in the wax and one opened But for some reason, I am not 100% sure its for the chipmaster. as I said, the wax sealed one came in a opened hard plastic cover/bag there is nothing to say the bag is NOT right for the part. I am trying to find a photo on google of one so I can compare it, but have had no luck the colchester parts manual does not show the part very clearly not does it give details |
Piero Franchi | 23/08/2017 10:37:27 |
124 forum posts 60 photos | I have just up loaded three photos of the lathe screw to my profile photos in case any one knows what its from |
Bazyle | 23/08/2017 13:52:35 |
![]() 6956 forum posts 229 photos | If your question is just whether it is metric or imperial you have at least 150mm there to get an accurate measure of the pitch. If the question is really whether it is for a chipmaster then you need to measure and list more of the key features as it is likely to be very similar to other models, Student, Triumph etc. Then probably go to a specialist forum like the Colchester yahoo group. |
Nick Taylor 2 | 23/08/2017 14:51:10 |
102 forum posts | From your pictures the nut looks exactly like the type fitted to my Chipmaster. I have never removed the screw so can't be 100% but it certinatly appears to be a Chipmaster part Edit - unfortunately the Colchester yahoo group has been dead for some time, I'm not sure where else to reccomend.
Edited By Nick Taylor 2 on 23/08/2017 14:52:06 |
Piero Franchi | 23/08/2017 14:56:11 |
124 forum posts 60 photos | I was hoping ti identify it so I can find a home for it, Its pointless me holding on to a New old stock lathe screw when I am sure there are people out there who would love to have and use this.
its no good for my lathe |
Clive Foster | 23/08/2017 15:55:45 |
3630 forum posts 128 photos | Many imperial TPI and metric pitch threads are closely equivalent sizes. Its relatively easy to get the approximate pitch or tpi in either system but telling the difference between an imperial thread and the closely similar metric one, or vice versa, is more difficult. The trick is to calculate the length of thread giving a half pitch difference over a measured length between the two very similar candidates. This is easy to see with a ruler as that measurement doesn't need to be anything like precise. Typically you need to measure over a few inches, maybe 5 to 7, for half pitch error. First time I did this was after buying a Bridgeport feed screw and nut set which didn't screw together and needed to figure out whether screw or nuts were wrong. I was able to verify that the 5 mm pitch Bridgeport feed screw I'd bought was in fact 5 tpi so the nuts were 5 mm as required. A tricky example as the two are close enough in size that worn nuts will go on the wrong screw in a fairly satisfactory manner. I have a spreadsheet somewhere with all the common pitches and tpi mapped out besides the half pitch error lengths in both metric and imperial dimensions. Fortunately there aren't many variations of tpi or pitches in common use. Clive |
