Piero Franchi | 27/07/2017 10:19:07 |
124 forum posts 60 photos | Hi Just I am on the last legs of a full restoration on my Myford super 7 Mk1 (see my photos in my profile)
One of the last things I will be doing is fitting the leadscrew, (I have a myford super 7 Mk1 with screw cutting gear box )
I have use of an other lathe (colchester bantam 1600) and was thinking of buying a acme all thread and machining the ends my self.
being a Mk1, the leadscrew does not go all the way through the gearbox.
so my question is, what is the thred, pitch etc ill need and where should/could I buy it from
Kind regards
JohnF | 27/07/2017 10:34:30 |
![]() 1243 forum posts 202 photos | Piers, try this link, not sure where you are but somwhere in my "stores" I have a Myford lead screw but for a much later machine than yours. Pm me if you cannot get fixed up with te link John http://www.abssac.co.uk/p/Precision+Lead+Screws/ACME+Leadscrew/101/#.WXm0ErHTWhA Also see this thread on this site http://www.model-engineer.co.uk/forums/postings.asp?th=65338 Edited By JohnF on 27/07/2017 10:38:22 Edited By JohnF on 27/07/2017 10:40:59 |
John Haine | 27/07/2017 10:53:21 |
5563 forum posts 322 photos | Standard pitch for the Myford is 8 tpi. I think the diameter is 0.75". Acme thread form. I assume that you have not converted the machine to metric - if you have then you could improve on Myfrod's "metric" conversion by having a 3mm pitch leadscrew rather than 3.175.. mm! |
Piero Franchi | 27/07/2017 16:00:36 |
124 forum posts 60 photos | No, not metric most of the intended work is going to be imperial
John F I will pm you now |
