SINO SDS6-2V linear correction
ian j16/07/2017 21:43:26
337 forum posts
371 photos
Hi.
I have just fitted a Sino SDS6-2V DRO to the X axis ( cross slide) on my ML7RB, I'm trying to fine tune the linear travel. I can enter the linear correction setup but how do you enter either +ve or -Ve before the digits ie. + 0.03mm or --0.03mm.
Ian
JasonB17/07/2017 07:23:21
If it is anything like entering other readings then enter the number and the +- AFTER the number then enter
So you would type 0.03 then + or - then enter but you don't need to enter a + just - if needed using the button with +/- on it
Edited By JasonB on 17/07/2017 07:32:35
ian j17/07/2017 09:01:21
337 forum posts
371 photos
Thanks for that Jason. You are correct , enter the digits then toggle +/- button if it needs to be -Ve. Easy once you knowsmiley
Thanks again.
Ian
