Brian Rutherford | 12/07/2017 22:13:37 |
109 forum posts 3 photos | Can anyone tell me the pitch of the m16 thread in the mt4 taper? I suspect it's 2mm but have no way of checking. Again I am assuming these things are standard. |
not done it yet | 12/07/2017 23:03:54 |
7517 forum posts 20 photos | I'm sure someone will confirm the pitch. But you could buy a bolt? Or take your MT4 along to somewhere that sells studding or bolts and check it out? Agri dealers, ironmonger/hardware stores, building suppliers all come to mind as possibles. I'll see if I can hunt out a bolt tomorrow, and try it, if nobody else responds. |
Neil Lickfold | 13/07/2017 01:42:26 |
1025 forum posts 204 photos | It will be M16X2 unless you have something special made. Neil |
John Haine | 13/07/2017 09:58:50 |
5563 forum posts 322 photos | Assuming that you are asking as you want to make a drawbar, go to somewhere selling studding, find a bit that fits, and buy a length, cut off what you need. For a slightly posher version, buy stainless studding. No need for any exotic steel for a MT drawbar, you do not need a very high retaining force, it would just make the taper stick. |
Brian Rutherford | 13/07/2017 14:01:56 |
109 forum posts 3 photos | Thanks for the replies. Can't get 16mm studying locally so was going to get off the net. Which is why I needed the size. Also need to get a tap. |
not done it yet | 13/07/2017 16:00:56 |
7517 forum posts 20 photos | Oops! Sorry, I wasn't thinking properly last night. Both my MT4 taper fittings are reducing sleeves, so no thread needed and no thread present.
Edited to add that it might be imperial if the tooling is old (5/8 Whitworth thread?). Edited By not done it yet on 13/07/2017 16:05:18 |
richardandtracy | 14/07/2017 10:05:41 |
![]() 943 forum posts 10 photos | I've found our nearest roundabout to be a good source for large size studding. As builders trucks go round it, they regularly shed unsecured bits of their load, and I've got M16, M20 & M24 studding off the tarmac. In fact, over the years the supply has exceeded my demand so clearing the road to prevent punctures [honest, guv Regards, Richard.
Martin Connelly | 14/07/2017 13:10:22 |
![]() 2549 forum posts 235 photos | Checking the pitch for something as large as M16 is not a problem, just put a piece of paper in the hole and press it against the threads with your finger. Remove the paper and measure the pitch of the marks on the paper. Martin C |
Brian Rutherford | 14/07/2017 23:20:43 |
109 forum posts 3 photos | Martin thats a really good tip that will come in handy in many situations. Will try that although I'm 99% sure it's 2mm |
