steam ports
Philip Burley13/06/2017 11:22:56
198 forum posts
I am making an engine , 2 cylinders , 1 inch bore , The plan doesn't give the port to cylinder end drill sizes . Would 2 x 3mm drillings pass enough steam ? Then a rebate into cylinder end 3 x2 mm at each drilling ? not much room for anything bigger
JasonB13/06/2017 12:09:59
What is the stroke, what is the inlet port size, is it just for display running or do you want it to do actual work, Wat is teh engine you have plans for?
J
Edited By JasonB on 13/06/2017 12:10:47
Philip Burley13/06/2017 16:51:22
198 forum posts
its a 2 cylinder traction engine , cylinders 1inch x 2 inch , steam ports are 1/2 inch x I/8 inch . R,S and J engine
JasonB13/06/2017 17:24:02
Two holes does sound a bit restrictive is there any chance of getting 3 x 3mm in?
By way of comparrison my 2" Fowler has a 2" stroke but larger 1.375" bore which works out about double the area of your 1" bore and ports are double at 1" x 1/8" , that has six 1/8" holes, you do have to pack them in a bit tightly though.
And another tightly spaced set of holes
Philip Burley13/06/2017 19:31:12
198 forum posts
a bit limited by the stud holding the valve chest on , but might be able to open up the drillings to 3.5 mm
