large bore Myford spindle nose dimensions
bricky16/05/2017 10:09:06
627 forum posts
72 photos
I am making a chuck backplate for my S7 plus.I have mounted a large billet onto the faceplate and turned the chuck register.I am boring to size for the register and the thread which I will cut at this setting.Normally I take off the chuck and workpiece and try the thread onto the spindle nose,but I can't turn the faceplate around as it will not clear the bed.I have one shot at this and I don't want to start again.I need to know the dimensions over the thread and the depth of the thread .
Frank
fivethou hammer16/05/2017 12:14:03
17 forum posts
Hi Bricky, I hope I can assist you.
Firstly, when my lathe came from Myford, there were two spare noses each mounted on a 2mt arbor. One was for the small bore lathe and the other was for the large bore which should give you the dimensions you need. Do you have these ?
Secondly, I am not sure I can assist with depth of thread, but can offer to measure any other dimension you would care to request...?
Gary
bricky16/05/2017 18:04:58
627 forum posts
72 photos
Thanks for replying Gary.
It is the depth of thread I am needing, as to disturb the set up and not be sure of engagement is what I am trying to avoid.I can't find a reference to the spindle nose dimensions and thanks again for trying to help.
Frank
DMR16/05/2017 23:43:28
136 forum posts
14 photos
The S7 Plus nose thread is documented as 42.5mm x 2mm pitch. So from tables you need the female thread depth of 0.54127 x pitch = 1.083mm. Hope that helps.
Dennis
bricky17/05/2017 06:24:57
627 forum posts
72 photos
Hi Dennis
Thank for that it is just what I need.I am now going to the workshop to set up my conversion set and get started.
Frank
bricky17/05/2017 22:34:38
627 forum posts
72 photos
Job done ,the help available on this forum is epic.
Frank
